Previous in Forum: Metal spinning in Inida   Next in Forum: Removing Hot Metal
Al P/M lubricant
09/01/2008 10:56 AM
Hello everybody
I wanted to ask about a proper lubricant for hot pressing of aluminum powder!
It is clear that I am not using lubricant cause there is no step for burning it, on the other hand I find it extremely difficult to get the powder inside a cylinderical die cause the powder takes upm very large volume.
So what should I do, get the powder inside the die with any other way or use a lubricant in a hot pressed powder?!
thank you in advance
Re: Al P/M lubricant
09/03/2008 6:51 PM
Try vibrating it. Vary the frequency for wide-range of particle sizes, or tune the frequency to fit a powder of uniform grit. A "lubricant" as an addition to the scintering mix would likely reduce strength. A volitile carrier which could be evaporated prior to scintering might reduce voids, but avoid flamables. Think non-hydrocarbon, non-water,simple light weight formulas such as Freon.
You might be interested in: Powder Production Equipment, Powder Metal Services
