Previous in Forum: sensors for measure tangential tension in botton channel   Next in Forum: 12 lead ECG circuit design
Temperature Switch
09/02/2008 12:19 AM
Hi,
Could anyone tell me the types of temperature switches and how they works. because i tryed a lot bt i could not found any literature about this.
Good Answers: 230
Re: Temperature Switch
09/02/2008 12:45 AM
Hello RAJ KUMAR
There are various types of "temperature switch", all of which rely on a physical force, either from the applied heat, removal of heat or both (not simultaneously, of course).
Trip = switching action.
  1. Thermal mechanical - Heat expansion = mechanical trip
  2. Bi-metal - Heater element on bi-metal causes thermal expansion = trip
  3. Thermomagnetic - Magnet loses magnetism on heating = trip - magnet regains magnetism on cooling
  4. Pressure - heat causes expansion of fluid (Gas or liquid) - sensed by pressure switch = trip
  5. Semiconductor -Semiconductor junction conducts more or less with heat = trip
  6. Resistance - Electrical resistance increases with heat = trip
  7. Inductor - Winding inductance varies with heat = trip
  8. Optical - Heat causes Optical junction to switch = trip
  9. Other.....You can try and think about them, reasoning from basic principles, then reply here, with ......
Hope that assists you....
09/02/2008 2:20 AM
Thanks
09/03/2008 1:03 AM
You can go to any site and search for "thermostats" & "temperature controllers". You will get lot of information.
All the best!
N. Mahadevan
Register to Reply 3 comments
josej (1); MAHADEVAN. N (1); Sparkstation (1)
