Previous in Forum: how to control electric motor with control ammeter   Next in Forum: adconvert pic
9 comments
Cheap Data Acquisition Card and Software
09/02/2008 9:02 AM
Hi,
I have a project here at work where i like to do data acquisition with inputs from a load cell, velocity transducer, displacement transducer, stroke speed sensor, and a thermocouple. Are there any cheap cards out there to do this with software?
ECUDesigner
Engineering Fields - Electrical Engineering - New Member United States - Member - New Member
Re: Cheap Data Acquisition Card and Software
09/02/2008 10:15 AM
One place that advertises as being "low cost" is Measurement Computing Corp
http://www.measurementcomputing.com/index.html
They have very many flavors to choose from.
Tom
09/02/2008 10:24 AM
Hi Tom,
I will check it out. Have you used anything from them?
ECUDesigner
09/03/2008 10:05 AM
I have not personally used one of their items, but we do have some here at my workplace (the newer USB based ones), and I'm pretty sure those who do use them have been pleased with them.
Tom
09/02/2008 11:30 PM
Consider USB based devices rather than plug-in cards as these will usually be cheaper. A Google search for "USB ADC" should get results.
09/03/2008 5:04 AM
What are your sampling rate requirements for each input? What outputs are you needing? What computer do you have available for this system and will it be a dedicated computer?
09/03/2008 8:00 AM
The sampling rate can be variable to 10, 000 hertz. I dont need any outputs and I will just be using a simple laptop. I like the software to be easy to use and I could just import the results into a spreadsheet.
ECUDesigner
09/03/2008 8:17 AM
I have a couple of DAQ 56 modules from Omega Engineering. They are pretty cheap and simple to use. Botyh digital and analog input as well as frequency/pulse. Can be configured directly to run any type of thermocouple from base menu. Has a software option that runs as an add-on to microsoft excel. Check out http://www.omega.com/ppt/pptsc.asp?ref=OMB-DAQ55
09/03/2008 8:33 AM
Hi AcesFull,
That looks like a good setup. We are looking at the sensors from Omega anyway so will look into this offering too.
Thanks,
ECUDesigner
09/03/2008 8:40 AM
I have also found them to have excellent customer service, which is HUGE in my opinion. Good luck.
Register to Reply 9 comments
AcesFull (2); Anonymous Poster (1); ECUDesigner (3); Rotag1 (1); tdesmit (2)
