Previous in Forum: STAR-DELTA   Next in Forum: Cheap Data Acquisition Card and Software
how to control electric motor with control ammeter
09/02/2008 7:14 AM
hellow, am Clement i have problem of over feeding on a particular machine named BEATER BLADE MILL which is having greater effect on the attached 45kw electric motor. i want to incorporate a control ammeter(anarloque) with lower and upper current limit to control the feed screw motor please how would i do the connection?.
Re: how to control electric motor with control ammeter
09/02/2008 9:44 AM
The current the motor draws is linearly related to the torque presented at the output shaft.
Limiting the current will cause the motor to stop or to stall. Most variable speed drives can be programmed to do this. Is that what is wanted?
Hobbies - HAM Radio - New Member United States - Member - New Member Hobbies - Hunting - New Member
09/02/2008 1:07 PM
Hi Clement and PWSlack,
I think he has two motors and he wants to start and stop the feed motor based on the load of the other motor.
In the case of an on/off type of thing, you may have problems with starting and stopping the feed motor. Shop around--there will be a lot of different types.
If you have the resources, I would agree with PWSlack and suggest you put a programmable VFD with analog inputs and get a current transformer with a 0-20mA (or 4-20mA)/0-10VDC output--Check Dwyer.
www.dwyer-inst.com/Products/TOC.cfm?MainCategory_ID=6&iCurrentCategoryID=216
With a VFD/ASD you would be able to program and control the feed with some precision and be able to ramp the the speed up and down. This may give your mill drive motor way more effeciency and it will get you away from starting and stopping the feed screw across the line (provided the material is somewhat metered).
Those who believe in telekinetics, raise my hand --Kurt Vonnegut Jr.
09/05/2008 11:55 AM
By will alone you say , you set your mind in motion . Well, your will has a lot more influence than just thinking, sappy juices aside . Your will chooses what to believe , and therein lies a door to life . I never laugh at life-life is no joke !
Dune was a great book, and the movie wasn't bad either- here's to Frank Herbert .
Have fun, Chas.
09/02/2008 11:13 PM
Is control the feed out of the question, to stop the over feeding ?
09/03/2008 2:22 AM
Hello friend,
It seems like you have two motors where the main mill motor rated at 45KW is fed thro' small feeding motor.
what you need is to control the feeding motor in order not to overload the main motor. This can be acheived by coupling a clutch to the feeding motor and controling the clutch DC supply through an analouge meter having two preset values (High/Low) for engaging and disengaging of the clutch. in this way the feeding motor continues running at all times.
Anonymous Poster (1); dadw5boys (1); Idodeclare! (1); Kilgore Trout (1); PWSlack (1)
