Previous in Forum: Neodymium Magnet Engine Design   Next in Forum: GDY-1 garage door opener
visual inspection tools needed
09/02/2008 5:26 PM
Dear Sir
We would like to introduce our company to u .We are scuba air service .We are visual inspection and hydrostatic test center for scuba cylinder (alum and steel)
We just pass IDEST course for visual inspection and hydrostatic test.
We ask for the following tools and machine to build our test center properly
1- Hydrostatic test machine for 400 bar test pressure with water jacket for single cylinder offer including manual and automatic control method.
2- The following thread gauge
3/4-14 NPSM Plug Gauge GO NO GO
3/4-14 NPSM Ring Gauge GO
3/4-14 NPSM Ring Gauge NO GO
2- Bore scope & gauge can go inside valve cylinder hall with dimension 2 cm. cm
To go inside the cylinder for 68 cm length deep to see and measure dents, pits and corrosion in the bottom of cylinder and the wall side the dimension of cylinder 20 cm
3- ultrasonic thickness gauge to measure aluminum & steel thickness metal
4- special key tools to install and remove valve on top of cylinder
5- If u have any tools can help us in this application plz refer us
Thank u
Bob
Re: visual inspection tools needed
09/02/2008 10:09 PM
No problem to offer above items.
200--400 bar hydrostatic test machine
portable ultrasonic thickness gauge and hardness gauge ( all kinds of hardness measure) with mini printer.
endoscoper, UT, x-ray RT, and PT MT etc. and RTI. you can send me message for all details.
I dont familiar with thread gauge, but I heard of it. I can get all kinds of the gauge from instrument factory
if you need laser ultrasonic test instrument, I suggest yuou buy it from canada company.
09/03/2008 6:04 AM
thank u iwaiting for offer
bob
09/03/2008 7:29 AM
Thank u for your replay we working according bs 5430
bob
