Previous in Forum: Minimum welding spacing in a 36" diam. piping spool?   Next in Forum: I Am Trying to Make This Thing
8 comments
Micro Float Switch
09/27/2006 3:59 PM
Looking for small float switch or sensor that can tell me if water level drops 1/8 inch.
Good Answers: 16
Re: Micro Float Switch
09/27/2006 11:30 PM
Try McMaster-Carr; they sell a lot of these things.
Ing. Robert Forbus
"Yeah, but will it fit?"
09/28/2006 6:48 AM
There are many types about, have you thought of using a light refraction sensor? these are extremely sensitive and could easily give you an 1/8 inch change in level...
In case they are called something else the type I'm referring to is the one which has a LED beam up to a lens which reflects the beam back to an integral light sensor. When the water covers the lens the beam is not reflected back to the sensor....
John.
09/28/2006 7:29 AM
Try GEMS, they specialize is level switches and sensors GEMSsensors.com
09/28/2006 7:40 AM
Canada - Member - New Member
Good Answers: 11
09/28/2006 9:12 AM
Most answers so far are on the usage on on-off type of sensor. Is this what you need or a sensor with an analog output?
How small do you need?
We built thermistor based sensors with a length of 15/16in, 10-32 threads and 5/16 hex. For these you need some electronics drive and decode the signal into a usefull output.
I have used plastic fiberoptic based sensors witch take minimal place (1-3mm diameter) at the process point but a small elecrtronic module is needed elswhere in your setup. Depending on the temperature and turbidity of the liquid, this a very interresting aproach. Glass fiber sensors can be even smaller.
You could also consider ultrasound sensors, with on-off or analog output.
Please contact us if you need further assistance.
Eric Girard
10/11/2006 11:50 PM
Try this indiginous swich I am using to stop my Water pump when Water-tank is filled
2 SS rods [1/8" dia] pierced through a rubber Cork, separated >1/3", Tips extruded 1/8" at difference can be used by hanging [mounted vertically] in the water tank while the longer rod's tip just touching the water. Electronic circuit will be needed to indicate/ switch on a light.
A ===============
| 1/8" |
B ====================
Wires connected to ends A & B to be connected to Circuit.
Other ends hanging downwards, tip of B just touching water
10/28/2007 5:45 PM
Check out Aquahub magnetic reed switches: http://www.aquahub.com/store/index.html
10/31/2007 10:06 AM
for a limited range application, small ultrasonic sensors on a chip have become very inexpensive. E.g. the Ping sensor used for robotics hoobyisrs has a range of 0.75-10 inches for $30. http://www.hobbyengineering.com/H2951.html
Less expensive waterproof units can be found in electronic component shops online fro just $2-4.
Anonymous Poster (3); Electroman (1); gigaconcept.com (1); Haajee (1); Ing. Robert Forbus (1); Mogg (1)
You might be interested in: Switch Boots, Audio Switch Matrices
