I have cleaned the carb. etc. float level is ok. Motor will idle rough but will not spool up to op. revs.
Question ; after removing float bowl i noticed that the main jet had unscrewed itself down . ( plastic carb. body with metal jet screwed into plastic threads. )
My question is this ... do i screw the jet up until it is tight or do i set it at a certain level ? Common sense dictates that the jet would be seated and other adjusments would be done by the outside carb. adjusment screw ??
This old 2 stroker is an excellent lawn mower with lots of power and light weight .
My dad gave it to me a couple of years ago and it beats the hell out of the usuall heavy 4 strokers that are most common . Its half the weight , so what more can i say .
Any carb. help would be appreciated .
