Previous in Forum: Weight of plate steel   Next in Forum: 2 cycle motor on a 25 year old lawn boy push mower
Differentiating Nylon6 and Nylon66
09/05/2008 12:27 AM
Is there any test by which we can differentiate Nylon6 and Nylon66. I has a component that was fabricated from Nylon but it is unknown to us that which Nylon it is, Nylon6 or Nylon66.
Paras Desai
Re: Differentiating Nylon6 and Nylon66
09/06/2008 9:49 AM
Probably the easiest test to determine the difference is their melting temperature. Nylon 6 melts around 420° F and Nylon 6/6 melts higher, around 500° F. The deflection temperature under load (DFUL) is higher with 6/6.
With all this in mind, there are exceptions. Get a material cert from the supplier to end all speculation.
"Imagination is more important than knowledge. Where knowledge is limited, imagination encompasses the Universe"
Good Answers: 18
09/06/2008 4:29 PM
You may also be dealing with 610 Nylon, but I agree that the best approach is to look at the melting (softening) point.
09/06/2008 8:15 PM
I believe the question was between nylon 6 and 66, not 610.
Nylons are semi-crystanlines and do not soften. They have a sharp melting point, although there are some amorphous ones in the market.
Good Answers: 18
09/06/2008 10:40 PM
Agreed, but melting point is also a function of the specific molecular weight of the polymer.
09/07/2008 11:50 AM
Melting point determination is one option. The other option could be the determination of the molecular weight. Nylon 66 is a polymer of hexamethylenediamine and adipic acid, whereas Nylon 6 is a polymer of caprolactam. The determination of carbon and nitrogen should be carried out through an analyzer called HCN Elemental analyzer.
09/09/2008 7:28 AM
Can you through some light on HCN analyser?
Paras Desai
08/05/2010 1:38 AM
Dear Friends , Hi I am sanket jejani , i manufacture glass filled nylon insulators for railway ,, previously we used Dupont Zytel nylon 66 33% GF,,,,it is very expensive material ..around Rs 200/KG or 4 $ per Kg ..... i am looking for material less than 2 $ or less than 90 rs ...... can any one suggest source for me ... I can accept scrap or regrind material , i asked for some regrind material from a company ..... but melting point which i require is 259 and above and presently i am getting 235 c ....can any one suggest how to increase melting point .....
Register to Reply 7 comments
agua_doc (2); Anonymous Poster (2); Paras Desai (1); plaasteek (1); prestigetrack (1)
You might be interested in: Faucets, Nuts, Lifting Slings
