Previous in Forum: Standard Steel and Aluminium Profile Dimensions   Next in Forum: RO Pump
Gear Box Hp
09/05/2008 4:55 AM
Hi ,
I want to calculate the input Power of a Gear Box have 22/11 crown (22teeth) & Bevel (11 Teeth) gear arrangement . input RPM 540 gear ratio 2:1
Please suggest
Good Answers: 230
Re: Gear Box Hp
09/05/2008 6:18 AM
Hello vikram raina
Input power can be anything from enough HP to turn the input shaft to trillions of HP.
Your information given is insufficient for a proper answer, because you evidently do not understand what Power is.
Advise output Power required, and the input power would be around 120% of the gearbox output power, for the range of 1HP to 10HP approximately, dependent on gearbox lubrication and temperature.
Reply here, with
Kind Regards....
Location: Next to the Prime Merridian (51°29'34.50"N 0°13'32.85"W)
Re: Gear Box Hp
09/06/2008 5:44 AM
The input power of your gear box is something you have to find out yourself. If you exceed its limits then it gets hot or worse you simply root it.
Making mistake is part of learning.
Re: Gear Box Hp
09/08/2008 1:59 PM
Golly, you need a lot more information than that.
What material; mild steel, toughened alloy steels, case hardened, cast iron, SG iron, brass, bronze? Material properties and manufacturing methods? Hardness of core and tooth surface? Tooth width? Diametrical Pitch, ie teeth per inch? Is the contact bevel with intersecting teeth or hypoid with shafts offset etc?
Well thats a start. There are different calculation formula for strength and wear and you have to take the lower HP result of the two for safety and continuous use. You can make a rough calculation if you have some of these values and guess others, but I dont think you will obtain an accurate figure.
gem
Good Answers: 16
Re: Gear Box Hp
09/15/2008 2:50 PM
All anyone can tell you with data given is that output RPM will be 270 based on the information.
What are you trying to do exactly? What power and or speed do you need?
Register to Reply 4 comments
Georgee (1); Isti80 (1); Sparkstation (1); Tim in Mexico (1)
