Previous in Forum: Thermal Sensitivity on Turbo Rotor Generator   Next in Forum: Motor
10 comments
Cylinders
09/06/2008 11:40 AM
what type of device controls a cylinders actuation
This discussion was "closed" on 09/08/2008 2:05 PM. No new comments are allowed.
Message from admins:
homework - I know, it's kinda like closing the barn after the horse....
Re: Cylinders
09/06/2008 1:47 PM
What kind of cylinder?
Bud Trinkel
Re: Cylinders
09/06/2008 2:51 PM
Looks to me like someone wants us to do his/her homework for them.
Perfection is achieved, not when there is nothing left to add, but when there is nothing else to take away
Re: Cylinders
09/06/2008 5:39 PM
For your information it's not homework but if you want to help you can if not please save your remarks for someone else.
Thank you
Lady B
Re: Cylinders
09/06/2008 10:10 PM
The question is a bit unclear. I will try to answer exactly the question:
A cylinder actuation is performed by an external force (or internal in the case of combustion cylinders). That force might be coming from a motor, steam, air under pressure, liquid under pressure, human force (you, probably, never started a car with a cranking rod) etc.
A device that controls a cylinder actuation would control all those forces.
Bridge rule #1: Nobody is as good as he thinks about himself nor as dumb, as his partner thinks...
Good Answers: 12
Re: Cylinders R for Everybody
09/07/2008 3:26 AM
I'm not sure I've ever heard of any cylinder being "actuated." Can you give an example?
Is there a reason your question showed up in this forum and not the General forum?
Re: Cylinders
09/07/2008 6:56 AM
Please Visit this site
www.festo.com
Aly Badawy
Re: Cylinders
09/07/2008 12:21 PM
Ha! Funny!
Good Answers: 16
Re: Cylinders
09/07/2008 11:27 AM
First, let's begin with terminology. I presume by use of the word "cylinder" you are referring to a pneumatic or hydraulic actuator. "Cylinder" is a slang word used to describe these devices and one that I prefer not to use. I also presume this actuator is part of a machine and it has more or less an electrically-controlled input. Your question is quite ambiguous and general so my answer is quite general.
Typically, such an actuator is connected to an energy supply source, be it fluid or air. The flow of energy available to the extension side or retraction side is determined/switched by an electric solenoid valve that is placed between the actuator and the energy supply. The electric solenoid valves fall into two (2) basic groups; normally-closed or normally-open. There are also proportioning solenoid valves in sophisticated arrangements, but let's keep it simple here.
The activation/operation of the solenoid valve is controlled by an input from a different energy source that may be switched by a PLC, limit switch, or an operator's pushbutton. Of course in the case where an actuator is manually controlled, there may be but a simple hand-operated valve.
So, the control of an actuator can be very simple (hand-operated valve) or be an extension of a machine's electrical control circuits. This is the best that I can do with this question.
Regards,
Ing. Robert Forbus
"Yeah, but will it fit?"
Re: Cylinders
09/07/2008 12:23 PM
Another one falls for the gag.
Re: Cylinders
09/08/2008 11:40 AM
Lets just say that between the cylinder and power source is a "Connecting rod"
Sounds good to me, next question.
Register to Reply 10 comments
Aly Badawy (1); Anonymous Poster (2); BudT (1); CowAnon (1); DGCYS (1); indel (1); Ing. Robert Forbus (1); Shawn_V_Elect (1); sirlburr (1)
You might be interested in: Hydraulic Cylinders, Air Cylinders, Rodless Cylinders
