Hello,
We are in process of changing around 3 meter section of kiln shell. Incidentlly the position requires welding the section at old weld joint by cutting from center. (offsetting joint from existing weld portion is not possible). We have to use E-7018 electrode with proper welding procedure (rebaking and preheating electrode)
SINCE NEW WELD FALLS OVER OLD WELD, DURABILITY OF JOINT IS IN DOUBT. CAN ANY BODY SUGGEST PRECAUTION TO BE TAKEN DURING WELDING OR POST WELDING, TO ENSURE DURABILITY OF WELD UNDER HIGH TEMPERATURE (400 degree celsius)???
SHAILESH
