Previous in Forum: paper presentation   Next in Forum: Sharing Folder with XP using a Crossover Cable
anybody professional at sql server
09/08/2008 9:59 AM
i want to use backup and restore database using visual basic 6 code. i use sql server 2005 as a database engine. i was using sqldmo but it only works for sql server 2000 and sqlsmo works only for .NET codes.
anybody who can tell me the way to backup and restore sql server 2005 database using visual basic 6 code.
Pathfinder Tags: sql server professionals
Re: anybody professional at sql server
09/09/2008 9:27 PM
Why do you want to use external programming VB6 or otherwise?
MS SQL server is quite capable of scheduling and executing its own backup.
If your problem is connecting VB6 to SQL server engine then check Microsoft ActiveX Data Objects in the VB6 reference section. This feature gives Command as well as Record Set access to the database. Command would include Backup and restore.
