Do your own homework. CR4 is not a homework cheat site. While some here might relish the opportunity to sharpen up old rusty skills by working the homework problem, consider this and consider it well. If you cheat on your homework by using someone else's answers, you are only cheating yourself, because the purpose of any homework or other college assignments is to help you learn, by practice, repetition, and self-discovery. (thanks STL Engineer)
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
