Previous in Forum: solutions and temperature!   Next in Forum: Material
Water chemical and Microbiological test results
09/09/2008 12:49 AM
Can anybody advise me if my water is safe for drinking, I send my water sample in the laboratory for testing and the result was as follows:
pH 6.53
Conductivity Us/cm 1351
Turbidity NTU 20
Nitrate mg/NO3 5.34
Chlorine mg/l Cl 365.1
Amonia mg/l NH4 <0.04
TDS mg/l Ca2 CO3 118
Total Coliform <1
Re: Water chemical and Microbiological test results
09/09/2008 3:35 AM
What did the laboratory say on the subject?
Safe? Biologically, maybe it is.
Tasty? Well, that's another matter. The conductivity and turbidity are a bit high, though the conductivity is within World Health Organisation standards for drinking water, and it would be wise to double-check on the nitrate and ammonia levels.
Is there a depth filter that might be introduced to reduce the turbidity levels? Screwfix catalogue (usual disclaimer)?
Good Answers: 101
09/10/2008 10:54 PM
"Chlorine mg/l Cl 365.1"
Is this your chloride or chlorine (i.e free chlorine) level? Whatever it is, it's really high. If it's chloride, better check your sodium content as well, because a high sodium content can cause hypertension and kidney failure. If it's chlorine, it's dangerously high. The normal chlorine level for disinfection purposes is only between 2 - 5mg.l, normally not exceeding 3mg/l.
