Previous in Forum: Foundation Fieldbus Instrument Testing   Next in Forum: White Radiation
Safety Integrity Level 2 (SIL2)
09/08/2008 11:02 PM
Anybody knows and assists about Safety Integrity Level 2? We have project that required SIL-2. What is exactly the purpose of SIL-2?
Thanks for advance assistance.
Save the earth, please consider the environment before printing this sheet
Pathfinder Tags: SIL 2
Re: Safety Integrity Level 2 (SIL2)
09/09/2008 2:34 AM
Hi ,
First SIL Has to defined By Risk graph analysis/Other Method depending upon the process hazard (Frequency, Consequence, Possibility of avoiding accidents ,Proability of avoiding accident ,Etc),
Depending upon your mode(Lowdemand /High Demand mode) use the proper equation defined in IEC 61508 Part 05
SIL 2 defines that your entire ESD loop containing,
1) Sensor (EG Pressure Transmitter )
2) logic solver (PLC)
3) Final element ( Shutdown Valve )
Sum of Each of PFD Value should be in the range 10 race to -02 to -03 (For SIL 02 )
For Prelimanary estimate you can use IEC 61508 part 05/06.
For more Detailing you can get the MTBF value from OREDA 2002
I suggest you Purchace IEC 61508 /61511 Series For more Info
09/09/2008 3:16 AM
Hi,
It's good information. Refer to the theoretical as mentioned, should the unit certify SIL 2? Is it allowed to utilize the unit that not SIL 2 compliance? Can we endorse from NON to certified SIL 2? Let's say for the sensor (EG Pressure Transmitter).
Thanks,
09/09/2008 3:41 AM
Bear in mind that SIL certificates are of no value without a copy of the report on the system. It is the report that is of value, not the certificate.
09/09/2008 3:46 AM
Ideally : No,
Since The PFD value will Increase If your Not complying with SIL level 02( Non Certified Pressure Transmitter ) That in turn will Increase The PFD avg of the Entire ESD loop , which will Lower the SIL rating.
Also its very rare that if your using Non SIL 2 Complaint transmitter you will be able to achieve the required PFD value for a SIL 2 loop
Better To get Certified device from Third party Inspection like EXIDA , RISKOLOGY
Regards
Jose
Register to Reply 4 comments
josej (2); PWSlack (1); Ynnor (1)
You might be interested in: Safety Laser Scanners
