Previous in Forum: elevator   Next in Forum: pls explain CuZn39 Pb3 F50 coating
9 comments
What is Full Flange Rating?
09/09/2008 3:24 AM
Pipe wall thickness is based on the line design pressure-temperature that is less than the Full Flange Rating.What is Full flange rating ?
Regards
Sachin
Be simple and specific for a great success in Life
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Technical Writing - New Member
Good Answers: 21
Re: Material
09/09/2008 4:16 AM
The size of flanges will obviously depend upon the size of piping to which they attach, and also upon the inside pressure that the flange must contain. The size of a flange in low pressure service can be smaller, and less expensive, than one in high pressure service. The organisations that developed pipe standards also developed flange standards for each size of pipe at different pressure ratings. The standardisation organisations arbitrarily selected seven basic pressure ratings or classes for each pipe size. The classe are 150, 300, 400, 600, 900, 1500 and 2500.
Hope this helps
Look over to the next challenge
Re: Material
09/09/2008 10:32 PM
I fully agree with your statement but how can it corelates with my query about full fange rating.
Thanks
Sachin
Good Answers: 21
Re: Material
09/10/2008 1:12 AM
Please, is not very clear for me what is full flange rating....The maximum value for pipe pressure....
Re: What is Full Flange Rating?
09/10/2008 2:05 AM
I'm interesting in design and fabrication of piping systems in accordance with ASME code, but it is the first time to hear the term "Full Flange Rating".
May be you mean that the rating of flanges used in certain piping system have a higher rating than the rating required by the code (ASME B16.5 or ASME B16.47). In other words, may be the pipe schedule is found to be 40, where the flange rating must be 150#, but the erector uses a flanges with higher rating, may be 300#.
09/10/2008 4:27 AM
In ASME B 16.5, you will find material based P-T rating table in which pressure values w.r.to temperature are given .like in table no.2.1.1, max pressure that can withstand by the flange is 19 bar (for 150# this is the full rating design condition).Whereas for 150# your line design pressure will be less than this, and you calculate your pipe thickness using line design pressure. This means flanges are always designed for full rating.
Pipe thickness may be calculated based on full rating conditions.In this case PRESURE(as per 16.5 table) / MAX. ALL.STRESS (as per B 31.3 table A-1, w.r.t temp.) ratio is calculated for each pressure value. The lowest value from the ratio is the the worst design condition used for pipe thickness calculation.
I hope your doubt is clear now.
09/10/2008 8:16 AM
Look in ANSI B16.5 for Pound Ratings of Flanges.
These ratings are based on Pressure temperature and materials used to make the flanges
The different ASME codes, accept these ratings.
11/01/2008 2:05 PM
Basically in full flange rating the pipe is designed stronger than the flange, ie the pressure bearing capacity of pipe should be more than flange pressure bearing capacity.
05/18/2023 2:57 AM
The <...Full Flange Rating...> exceeds the pipe rating. That way, the pipe fails first on rising excess pressure.
If it were less than the pipe rating, then the flange will fail first.
Register to Reply 9 comments
Abdel Halim Galala (1); Anonymous Poster (4); PWSlack (1); sachin_rastogi_in (1); user-deleted-1104 (2)
