Previous in Forum: Evolution   Next in Forum: Microwaves
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member Technical Fields - Technical Writing - New Member Engineering Fields - Construction Engineering - New Member India - Member - New Member Engineering Fields - Nanoengineering - New Member Safety - Hazmat - New Member
Education
09/29/2006 3:10 AM
There are 'undergraduate courses' and ' Postgraduate courses' offered by universities. Why the 'undergraduate' courses cannot be termed simply as 'graduate' courses, or is it that the two terms , 'undergraduate' and 'graduate' courses, mean differently, and if so can any one clarify on the same?
nvmani
Pathfinder Tags: University course
Good Answers: 918
Re: Education
09/29/2006 8:32 AM
Generally, here in the states it is undergraduate (a typical 4-year study), followed by masters degree (an additional 2 years), and finally PhD (Piled Higher & Deeper).
Postgraduate would be additional research beyond the undergraduate studies and would include masters and/or PhD degrees. Postgraduate is also known as graduate.
If it doesn't make sense, then it might be by design just to add mystery to the whole idea of higher education.
The thought process goes like this, "I am confused as to the meaning of undergraduate, graduate, and post graduate work, but I am too embarrassed to ask." This leads to the pursuit of higher education in the vain hope that it will be explained somewhere along the 12 years that you toil away in search to the meaning of it all. After completing your PhD there is a short time of euphoria as you mentally pat yourself on the back for your achievements. However, afterwards you realize that the original quest that drove you through 12 years of hell has remained entirely elusive and unresolved leaving a vast hole in your life, which leads to one more question, "Why?" Unfortunately, your peers seem to ignore the whole question, probably because they do not know themselves.
Realizing there is no place to turn you are forced to stop shaving and changing clothes and hang out on dark street corners, drinking out of brown paper bags, and large cardboard boxes become your most trusted friend.
Good Answers: 247
Re: Education
09/29/2006 11:30 AM
In the US, undergraduate courses are those you take before "graduating" basic four year college. Hence "under" graduate. Generally, graduate courses are those you take after graduating and can lead to a Master's or PhD. Postgraduate courses are normally those that you take after obtaining a Master's or PhD. It's more than a little confusing. "PostDoc" is a term often used used for educational work you do after your PhD, and is another term for postgraduate education.
Register to Reply 2 comments
