Previous in Forum: Non-Ionic Surfactants, where for art thou?   Next in Forum: PAINTS
pressure safety valve
09/10/2008 2:47 AM
in most of working refineries, it is seen that there are some PSVs on top of crude atmospheric column which have not connecetd to flare header. but they connect to atmosphere. what's the philosophy of this type of design?
Good Answers: 61
Re: pressure safety valve
09/10/2008 12:18 PM
In what country are these PSVs you talking about?
In the USA and most other countries it is against the law to vent hydrocarbons or toxic fumes to atmosphere.
Do it once and do it right
09/12/2008 10:00 PM
This is a way of economy via absence of piping if the process is " non-toxic ".
09/13/2008 2:58 AM
thanks freidun for your reply.
as you know, relieved compounds from PSV on top of atmospheric column are hydrocarbons which are flameable. so sending this compounds to atmosphere creates hazard area.
i have found that relieved fluid from this PSV can be eighter liquid phase or vapor phase. what's your idea in this regards?
09/13/2008 4:33 PM
Dear HD,
These are "process specific" operations. In old days this type flammable gases were forwarded to a stack and one let them burned at top of stack.
Nowadays i'm not sure the way is this and they could be reused with a purpose of "co-generation" process say with a steam boiler after some specific acquisition procedures.
I'm not a chemical engineer but electronics and i can speak on the basis of what i've seen at automation area.
regards
Register to Reply 4 comments
feridun (2); Hossein Deldari (1); PennPiper (1)
You might be interested in: Gas Flares, Video Cables, Cable Assemblies
