Previous in Forum: Power factor effect to loop system   Next in Forum: cementing in high voltage insulators
8 comments
DC Contactor / FGC Relay 10A inductive
09/11/2008 5:39 AM
Has anyone out there come across a (reasonably priced and sized) contactor or forced-guided-contact relay (min. requirement 1NO + 1NC), 24VDC coil, capable of switching a 24VDC 10A inductive load (DC-3, min. 106 operations)? The NC contacts could be low-current (for monitoring).
Most contactors, even those rated at ~100A 240VAC, come down to 5A @ 24VDC.
The app. is to kill the power to motor drives in a Safety related control system. I know that DC motor contactors are available, but the ones I've seen have been big and expensive.
Thanks in anticipation.
Good Answers: 18
Re: DC Contactor / FGC Relay 10A inductive
09/11/2008 9:29 AM
How about an automotive (as in truck) or heavy equipment (as in bulldozer) contactor? The ones used for starters have to switch high DC inductive loads. A separate NC relay can be used for sensing.
09/11/2008 10:50 AM
Damn good idea re. the load switching - a good cheap & reliable solution.
Trouble is, in a safety system, the NC (monitoring) contacts have to be mechanically linked to the NO (control) contacts, as in a contactor or FGC relay. This is to make sure that if the control contacts weld, the monitoring contacts stay open when the coil is de-energized. The monitoring system detects this state, & locks out to safety.
Thanks anyway, Bill - keep the suggestions coming!
Good Answers: 18
09/11/2008 11:27 AM
O. K. How about this R51 job from NTE . . . Has rating of 50 A @ 14 V, so it should be able to handle 10 A @ 24 V. There's also a R54 rated at 30 A @ 28 VDC. See this page.
09/11/2008 5:23 PM
Thanks again, Bill, but I still need the mechanically-linked auxiliary contacts for monitoring (R51 job from NTE is a single-pole thing, SPST or SPDT).
Good Answers: 18
09/12/2008 7:44 AM
One of the R51 series has SPDT contacts.
09/11/2008 11:00 AM
You may want to talk to www.gigavac.com who have a GX11 contactor for about $125 that migh do the job. It's a SPST main contacts with SPDT auxillary contacts.
09/11/2008 5:25 PM
Thanks, Guest, I'll give the UK distributors a call in the morning. Could be onto something.
Good Answers: 15
09/12/2008 7:19 PM
hi John,
Have you tried Albrights?
we use them for 24Vdc motor control on anything > 10A
Tel: +44 (0) 208 390 5357
Fax: +44 (0) 208 390 1927
Sales Email:sales@albright.co.uk
Technical Email: technical@albright.co.uk
Mail: 125 Red Lion Road, Tolworth, Surbiton, Surrey, KT6 7QS, England
or, as previously suggested go automotive;- try http://www.boschmotorsandcontrols.co.uk/relais/relais.pdf.
you might find what you are looking for there.
good luck
chas
Register to Reply 8 comments
Anonymous Poster (1); Bill (3); capblanc (1); JohnDG (3)
