Just a few questions, if you folks won't mind again, but please let me explain first.
I have been advised by owners/operators of two different microbreweries
-- each producing 5,400 barrels per year -- that their usage of CO2
(which they purchase by the ton) is as follows:
1.
"We use 2000 lbs. a week, topping our 6 ton tank off every 5 weeks (we
never let it get below 2000 lbs). 5400 bbls. annual volume, 80% ales."
... = 104,000 pounds of CO2 per year.
2.
"Our brewery ... (has) ... same annual production, same bottle filler,
we only brew 120 bbls. of lager a year - rest ales. We use just shy of
4000 lbs per month, 3800+-, and fill our 2 ton tank once a month."
... = 45,600 pounds of CO2 per year.
As shown below, they are probably also venting that much CO2 into the
air, so even the second more conservative figure is a heck of a lot of
'greenhouse' gas to be releasing unnecessarily. In fact,
microbreweries can legally, in most places, be almost three times that
size (15,000 barrel/year production). I have therefore been
searching for an alternate solution -- using the CO2 that is produced
by the brewery during fermentation just like the BIG breweries
do. I'm sure someone here will correct me if I'm wrong, but here
are my calculations:
Fermentation = C6H12O6 → 2 CO2 + 2 C2H5OH
Hydrogen = 1.008
Carbon = 12.01
Oxygen = 16.00
(12.01*6)+(1.008*12)+(16.00*6)= 180.156 ... which is converted to ...
2*(12.01+(16.00*2))=88.02 "CO2"
2*((12.01*2)+(1.008*5)+16.00+1.008)=92.136 "ethanol"
and ... 88.02+92.136=180.156 ... so almost 49% of the weight of sugar is converted into CO2 -- 88.02/180.156=0.4886
Now, one barrel (31 gallons) of your typical 5% 'alcohol by volume'
beer, requires approximately 26 pounds of sugar and should generate
26*.4886= 12.7 pounds of CO2 per barrel. A microbrewery producing
5,400 barrels/year of that same beer would therefore produce 68,580
lbs/year, and although some of it would remain in solution, most of it
just goes into the atmosphere.
Why 'buy' 45,600 lbs/year (the conservative figure, above) and at the
same time vent probably that much or more from the fermenters. Note:
ventillation from the fermenters will also contain some degree of
moisture, a bit of ethanol, and a small percentage of other alcohols
and various compounds; I therefore presume that any salvaged CO2
would need to be scrubbed and dried first before being stored until
needed. The problem is that the few brewers I've been able to
check with, including on brewing forums, are unaware of such equipment
-- but that doesn't mean it isn't out there, or is impractical, or
can't be made.
QUESTIONS:
1. Does my math, above, make sense? Any errors?
2. Do any of you engineers out there know of any way to do what I
propose on a scale anything like the above -- from 5,000 to 15,000
barrels/year, i.e., salvaging from 40,000 to 120,000 pounds-CO2/year?
3. I don't even know what to look for; is 'scrubber' the correct
term, and what would I need? ... just some activated charcoal and a
dessicant?
4. Is it practical, on that scale, to compress the CO2 and store it?
5. Any other thoughts or suggestions?
Thanks.
Bill Velek
