Previous in Forum: gate valve in refinery   Next in Forum: Need help identifying equipment to reduce CO2 emissions from a small brewery
Paint for internal metallic pumps parts?
09/11/2008 4:48 AM
Dear friends
Please I want to know the chemical material to paint the internal metalic pumps parts
to resist corrosion?
thanks
Good Answers: 123
Re: Paint for internal metallic pumps parts?
09/11/2008 10:00 PM
Corrosion of what from what. Why don't you use a pump designed for the product you are pumping?
Bob
09/12/2008 2:40 AM
Dear bob c
1-the corrosion of the internal metalic parts from chemicals,water,etc.
2-I have to make preventive maintenance for pumps using this paints to make the pump life longer. I heared about these paints , which are these? this is my question.
thanks
Aly
Good Answers: 123
09/12/2008 11:15 AM
Dow Corning Chemical, and Rust-Oleum are two manufacturers of epoxy paints that should be able to advise you on the particular formula to use with your particular chemicals. try to contact either of those companies directly. Good luck.
Bob
09/17/2008 7:13 AM
There are plenty of materials that are resistant to different things. Simply select a pump that has wetted parts that are compatible with the fluid being pumped (which is not stated in the original post). The pipeline material can often give guidance:
  • 316L stainless steel with a high polish for foodstuffs and beverages
  • Cast iron for cooling water and many organic non-acids
  • plastics for many acids
  • etc. etc.
Corrosion charts will give details of compatible materials and fluids.
It is most uncommon for the internal surfaces of a puimp to be painted. Epoxy-coated maybe. Paint? Hmmmmm........
09/17/2008 7:55 AM
Dear PWSlack
I have heard about the materials that are suitable for such function.Because I am mech. eng. I decided to ask our friends , the heros of chemistry ,specially when I read a peom by a chemical eng. and some friends who pointed with the sword crying : is there any question? I hope that I can find agood one who can save us from the stormy waves.
thanks
Aly
09/25/2008 7:45 AM
09/25/2008 11:20 AM
Dear Strider
thanks for your great effort to reach our aim.the site corrosion preventation helps in this direction.we can concentrate at HOW TO RESIST CORROSION by coating and painting? which of these coating and painting?
best regards
Aly
Register to Reply 7 comments
Aly Badawy (3); bob c (2); PWSlack (1); strider6 (1)
