Previous in Forum: PAINTS   Next in Forum: Paint for internal metallic pumps parts?
gate valve in refinery
09/11/2008 12:07 AM
How can we know that we have to use normal gate valve or bellow gate valve in refinery.Bellow valves are required for critical services,high Pr. & Temp.
Pl. give clear understanding of this.
Thanks
Sachin
Be simple and specific for a great success in Life
Re: gate valve in refinery
09/12/2008 2:54 AM
Such gate valves with bellows are more required for critical services than for high pressure or high temperatures.
Critical service like H2S presenting contents and like, where even, occasionally, a drop of leak at gland is intolerable . Bellow is expected to give 100% protection against such gland drips.
But, I've seen when the bellow failed/cracked, the leaks were objectionably very high. This is because the stuffing box elements under the bellow are un-attendable by easy means on service. Failed stuffing box element may even be due to normal wear & tare and ageing.
09/12/2008 6:19 AM
It is undertood where application involve High Temprature and high reactive medias as mentioned earlier this valve provide more life and less maintenance.
Also the leakage through this valve is off higher degree and to recent enviromental standards.
Register to Reply 2 comments
