I want to measure Acid levels within Automotive Car Batteries via some non-contact method if at all possible.
I am presently using the resistance of the acid to do this using a Digital Height Gauge fitted with a probe having a Tungsten Carbide tip which is brought down to make physical contact with the Acid, rigged elctrically to both audio & visual alarms. As all is done manually, I am experiencing trouble this way as "Miniscus" jumping is proving to be problematic and the whole set up is terribly slow as I have to guide the probe into the Battery Vent Plugs, 6 in all. Is there anything out there that can do this "Safely" & "efficiently"?
Best Regards, Metman.
