Previous in Forum: White Radiation   Next in Forum: Pressure Relief Valve
Open / Close Drain Vessel
09/11/2008 9:40 AM
Dear All,
Have you came across open / close drain vessel in the process industries? What is the used and different of each vessel?
Thanking you in advance.
Re: Open / Close Drain Vessel
09/11/2008 5:21 PM
closed drain means the system is sealed and can be exposed to pressures up to the highest pressure that the drain is connected to. The fluids flow because of a higher pressure of the inlet than that of the outlet.
An open drain is always open to the atmosphere and the highest pressure would be the height of a coulum of a fluid abve the exit. This system flows be gravity or sloping of the lines.
Reply to Forum Thread
