Previous in Forum: Open / Close Drain Vessel   Next in Forum: acoustic type flow switch
Pressure Relief Valve
09/12/2008 7:05 AM
i have a line discharge pressure of 6.9 bar what would be the precise pressure rating of the PZV i need to used.
Re: Pressure Relief Valve
09/13/2008 2:55 AM
Hello,
Kindly Refer API 526 table 1 to 14 ,they have given the Inlet Outlet rating for each
value of Pressure and relieving temperature,depending on the Bore diameter.
Regards.
Jose
10/08/2008 3:35 AM
What is the fluid and its temperature?
Register to Reply 2 comments
