Previous in Forum: Walther spray gun replacement   Next in Forum: Discussion Closed
ph meter
09/12/2008 3:40 AM
how much the standard pressure ranges of ph meter use in caustic soda injection system.
Re: ph meter
09/12/2008 4:24 AM
I don't understand the question.
A ph meter wouldn't be subjected to any pressure.
A ph probe may be subjected to some pressure as it will be installed in the liquid flow, but usually at a low flow, low pressure test point.
The pump which is dosing the system may be working agains pressure from 0-10 bar or more...
Re: ph meter
09/13/2008 8:29 AM
Welcome aboard!
I don't quite understand either. the pH is typically expressed as if at standard temperaure and pressure. I can't think of a condition under which pressure would cause pH to vary, except a pressure so blazing high the ions won't dissociate! Lower pressure doesn't influence the bonding to cause more dissociation. And if you mean will the pressure of the injection system influence the meter itself, I doubt it, but there are probe systems built for rough service (some are very delicate). Are you measuring the injected caustic or the resulting solution?
Re: ph meter
09/13/2008 4:42 PM
i am measuring the injected caustic depend on the level of ph of the liquid flowing to the process.
Re: ph meter
09/17/2008 8:29 AM
....then the pressure in the line at the injection point is the pressure that the pH probe will need to be rated to withstand.
Register to Reply 4 comments
EnviroMan (1); ernesto_maglasang (1); PWSlack (1); user-deleted-1105 (1)
You might be interested in: pH Electrodes, pH Transmitters, pH Instruments
