Previous in Forum: Why does my room air conditioner trip ELCB?   Next in Forum: Car Stereo doesn't work
10 comments
High tension transmission
09/12/2008 9:20 AM
Dear sir ,
In a high tension transmission in mountain path.In a particular location if more no.of ZIgzag bends presented (220 kv) .If there any other possibilities to get without rain fall on a particular location
Engineering Fields - Power Engineering - Projects Engineer
Re: High tension transmission
09/12/2008 9:41 AM
My Friend
where is the question?
A wise person will understand more from a Foolish question than what a Fool will understand from a Wise Answer
09/12/2008 5:50 PM
I'm with Sak. I don't have a clue as to what you question is. Please restate it so we can understand.
09/13/2008 3:34 AM
Are u refering to a tower line?If it is due to location u have more zig zag bends.In hills normally the tower location is to be selected where stability of foundation can be ensured.Second location has to be as far as feasible offer protection from falling of boulders etc.There are more factors which limit tower location positions.Its difficult answer without looking at the site.Try re routing .Now what is the rain business? transmision lines are exposed to all vagaries of weather and are designed for that.So why protection from rainfall pl clarify.
09/13/2008 9:30 AM
Thanks for your response sir.
Its real fact on Nilgris mountain.
The two power tansmission tower was located for such a distance.
The two tower connection is more zigzag bends.
at last 12 years no rain fall in this place.why ?
09/13/2008 2:52 PM
is it true?
unbleavable one!
ponnusamyaee tneb thanjavur
09/14/2008 1:44 AM
Please be cohesive in your statements.
Can't understand what you are trying to imply.
"The two power tansmission tower was located for such a distance."
What is meant by this - what distance are we talking about.
"The two tower connection is more zigzag bends."
How can overhead line conductors between two towers create more zigzag bends.
This one is giving me the currents.
"at last 12 years no rain fall in this place.why ?"
Are we discussing here some mysteries of the unknown.
Atlas Shrugged - JGD
09/15/2008 9:36 AM
What i am trying to say the distance between the two towers are so short.
The continous towers are zigzag in small location.
In a small place but the more zigzag bends are presented.
At this position what are the defects ?( I thing the climatic condition chaged on particular spot)
09/15/2008 12:10 AM
As said earlier in hilly terrain it is common to see line being not in straight line.Rarely you will have a suspension tower .What I understand is that the line takes a deviation throgh an intermediate tower and again is back on the routing.IT depends on site conditions.One thing for sure is it is no way connected with presence or absence of rainfall.
09/15/2008 9:35 AM
Thanks for your response.
09/16/2008 3:20 AM
The tower spotting depends on Clearance u get at the lower most point of the conductor between two towers.u can have high but few towers over entire line length or have shorter towers more in number for the same .This holds good in plain terrains .In India we have a practice of tensioning off every 3-4 km max.In abroad lines run for 30 k-40km between two tensioning off points on suspension towers .In hills u spot the towers depending on clearance, tower location.Too many towers in short distance could be due to various reasons which can be answered only with more details like what is the designed normal span, profile of the route and so on.As to rainfall it can be no way related to the line.There are many transmission line I have done in mountanous regions where rainfall continues to be as before.It could be due to some other reason.Pl. talk to some locals who have been around more than 12 yrs in that area as what was the rainfall then .Is it 12 yrs since line was constructed?
Register to Reply 10 comments
Anonymous Poster (2); Current Maarey (1); nesubra (3); SAK (1); sivarajan89 (2); wareagle (1)
