Previous in Forum: why tanks are hydrocaarbons storage are designed spherical shape   Next in Forum: trouble shooting of steam turbine
water pipe thickness
09/13/2008 2:50 PM
where can i get tables and calculations for the water pipe thickness in proportion of diameter and pipe material
Re: water pipe thickness
09/13/2008 11:41 PM
Are you asking what the standard sizes of pipes are? If so, there are a lot of websites with charts - just Google "Pipe dimensions"
Or are you asking what a required thickness is for a certain condition? If so you need to provide a fluid pressure and applicable code. Even then it will be a little tricky to give you an answer because depending on the code, there are other considerations including pipe layout (dimensions), support distances, thermal expansion, seismic, weight of insulation, etc ...................
Good Answers: 19
09/14/2008 11:40 PM
???? What water pipes? Galvanized/PVC/Stainless Steel?
They are in gauge/schedule 20/30/40/ etc.
Ask your Pipe Supplier to give you the Chart or look up the internet.
09/15/2008 1:08 PM
Anonymous Poster (1); ducon (1); Randy Conner (1)
