Previous in Forum: How Do I Remove Embedded Metal From My C5 Collet?   Next in Forum: difference between hydraulic & pnuematics
Gear measurement help needed
09/13/2008 5:58 PM
I am looking for someone who knows how to measure gears.
I need this rack to be pulled down by these series of gears.
Each system is the same in the picture I am providing but I need the gears of each system to be able to pull down separately the distance of 1 inch, 2 inches and 3 inches.
Also if you can please provide the equations you used and any suggestions to make the system more efficient, thanks.
Here's a link to the picture of the system:
http://i6.photobucket.com/albums/y2...a/GearTrain.jpg
The pole connecting to the Worm Gear will be connected to an arm that will be turning an arm connected to it 3/4 an inch in distance.
Here's a picture of what I mean:
http://i6.photobucket.com/albums/y2...kzelda/Pole.jpg
I also would need calculations for the gear measurements to be able to bring that rack down those distances if the arm were only turned 1/2 an inch.
The circle will be 6 inches in circumference for the arm that turns 3/4 an inch and 4 inches in circumference for the arm turning 1/2 inches.
Also, please let me know if the circle needs to be bigger to compensate for the possible size of the gears.
Pathfinder Tags: Gear measurement help needed
Re: Gear measurement help needed
09/13/2008 9:56 PM
Your pictures are not coming through. The link says they have been moved or are deleted.
09/14/2008 2:04 PM
Let's try these links instead:
This is the overhead view:
<a href="http://s6.photobucket.com/albums/y208/linkzelda/?action=view&current=Pole.jpg" target="_blank"><img src="http://i6.photobucket.com/albums/y208/linkzelda/Pole.jpg" border="0" alt="Photobucket"></a>
[IMG]http://i6.photobucket.com/albums/y208/linkzelda/Pole.jpg[/IMG]
This is the side view:
<a href="http://s6.photobucket.com/albums/y208/linkzelda/?action=view&current=GearTrain.jpg" target="_blank"><img src="http://i6.photobucket.com/albums/y208/linkzelda/GearTrain.jpg" border="0" alt="Photobucket"></a>
[IMG]http://i6.photobucket.com/albums/y208/linkzelda/GearTrain.jpg[/IMG]
09/14/2008 2:05 PM
09/15/2008 1:40 PM
also try Rush gear's website rushgears.com,I represent a Korean Gear manufacturer,you are not going to receive this info free of charge,what you are asking comes with a companies time and effort=money.
Good Answers: 123
09/14/2008 1:57 AM
Try contacting Boston Gear. They earn a living making gears for other people. They should know what you need. Good luck.
Bob
09/15/2008 1:21 AM
Dear Partner,
We are professionals in Gear making, also metallurgical and materials Engineering.
I will breakdown the required information u needed. Bye.
Regards,
Sola
Tel: +234(01) 6608610, Mobile: +2348025535595
Register to Reply 6 comments
Anonymous Poster (3); bob c (1); Kain (2)
You might be interested in: Metric Gears, Gears
