Previous in Forum: is marine oil not needed in marine engine or vessel anymore?   Next in Forum: Liquid to Solid Gel (and Vice Versa)
sulphonation plant
09/14/2008 3:48 PM
we have problem with this plant whenever we start it, its creating lot of white smoke which is heaviour than air and settle on the ground. which is hazardous. what is the problem. how can i solve this problem. please guide me.
pigging of pipeline will help me or not.
thoughts becomes things.
Re: sulphonation plant
09/14/2008 5:06 PM
Make a small batch in lab. and check your formulation.
09/14/2008 9:56 PM
Sulphonation often is carried out with Falling Film Reactors, and if you are using the same then your cooling water is not cold enough. vapour phase reaction is taking place and then forming solids that later settles on the ground
EditorGBAnalysts - Give a boy fish and he will eat may be for a day, but teach him how to fish and he will eat everyday.
09/15/2008 12:01 PM
ADDENDUM
For some insight into the Transport Phenomena of Falling Film [fluid dynamic-based] equipment see our article at:
www.gbanalysts.com/Reading%20Room/Situation%20Analysis/BiodieselTechs/ffilmmeOHevaporativebddistill.html - sorry, link no longer available
However, for some more insightful analysis of Faling Film Sulphonation Reactor, look for the compilations of the 2nd World Congress of Chemical Engineers 1981 held in Montreal, Canada. I believe that in the vol 2 - if not also check vol 1 - there is an article entitled "Mathematical Modeling of Falling Film Sulphonation Reactor". That should give you some guide. The representation of the interfacial differential equation in that article could be repackaged into Voltaire Integral Equation. Evaluate the mathematical "norm" of the integral operator making sure that the norm is less than 1 (unity) to ensure solution (Existence Condition) and the combination of operating values that keeps the "norm" less than unity should always work. If you should have problem with this contact me again but directly at (editor @ gbanalysts.com)
Good luck
Good Answers: 230
09/14/2008 10:12 PM
Hello sandeep lokhande
The "White smoke heavier than air" is probably a mixture of SO2 and SO3, both of which are extremely corrosive to equipment and dangerous to persons and animals.
As "Guest" above suggests, you should check your formulation, because your plant should not emit these fumes.
Please advise from where the "White smoke heavier than air" is actually being emitted. (From exactly where in the plant)
Reply here, with
Kind Regards....
10/16/2008 2:30 AM
to be instal electro static precipitar & alkely scrubber
NANAWARE SHRINIVAS
+919816429998
10/17/2008 2:53 PM
how it will help and where to install
because i have to convince my management
please help me.
Register to Reply 6 comments
Anonymous Poster (2); editorgbanalysts (2); sandeep lokhande (1); Sparkstation (1)
