Previous in Forum: pleased to recieve lighthouse Visibility advices   Next in Forum: Welding
Degreasing Electronic Cards
09/15/2008 9:24 AM
Can anyone find me the name of any recommended product for the cleaning purposes (Degreasing,Overhaulling purposes) of the elctronic cards...
Shall i use Thinner Solution for degreasing the Electronic Cards?
It is Observing that during washing with thinner solution some electronic components coated with plastic starts reacting resulting roughness and sometimes its melt the plastic coated components.
Good Answers: 40
Re: Degreasing Electronic Cards
09/15/2008 11:24 AM
No! Do not use thinner!
Virtually all circuit cards are coated and will react with the thinner.
Here are a number of possibilities
Isopropyl alcohol
http://www.polywater.com/typehp.html
Many other chemicals specifically designed to clean circuit boards.
Soap and water, with proper drying afterwards.
09/16/2008 12:27 PM
Thanks for your reply,one more question !!!
ISO PROPYL ALCOHOL is the chemical name of Thinner? or something else... kindly let me know the chemical name of the thinner..
Good Answers: 40
09/17/2008 11:34 AM
The following chemicals are known as thinners
Paint thinners include:
09/16/2008 12:48 AM
You can use CRC spray for electronic componets/cards.
09/16/2008 1:40 AM
Mostly I use "white spirit"(*) and a soft brush to clean Printed Circuit Boards. It does not harm plastics and doesn't fade colors. It dissolves grease and dirt. After repairing don't forget to spray a suitableprinted circuit laquer on it.
Good luck !
(*) not sure if this name is known in English
44mEurope
Good Answers: 40
09/17/2008 12:30 PM
White spirits will dissolve any laqueur based coatings on a circuit card. Not recommended!
09/16/2008 6:27 AM
Make sure power is cut off.I've used WD-40 or mineral spirits with a gentle brushing like Europe said,to get the bulk of the deposits,followed by CRC electronics cleaner that Mogambo uses.It saves on the CRC . The WD-40 disperses the deposits,then the CRC washes it all away leaving a dry surface.Don't use compressed air to dry electronics most have moisture and traces of oil.Just make sure it is dry before putting it in service. Skip
Hope for the best,Expect the worse,Take whatever comes
Register to Reply 7 comments
44mEurope (1); mogambo (1); Skipper (1); techno (3); zohaibmoazzam (1)
