Previous in Forum: Flushing procedure   Next in Forum: Electric Bike Motor
Wanted: 3-Way Dual Shut-off Valves Between Vessel and PSV
09/15/2008 9:37 AM
Hi, I am looking for 3-way dual shut-off valves installed between vessel and pressure safety relieve valve. The valves need CRN# from Ontario and meet ASME VIII Div.1 or ASME B31.1 requirements The 3-way valves will be installed on the following system:
Item
Fluid
Component/System Pressure (psig)
PSV set Pressure (psig)
Required Capacity
PSV Inlet Connection
1
SteamExpansion Tank / 15045645 lb/hr¾" MNPT
AirReceiver / 200200187 scfm¾" MNPT
AirPipe line / 10010068 scfm½: MNPT
AirReceiver / 100100366 scfm¾" MNPT
5
AirReceiver / 100100940 scfm1 ¼" MNPT
6
NitrogenPipe line / 1251252.3 scfm½" MNPT
7
HeliumPipe line / 151524 scfm½" MNPT
8
WaterRegulator / 656514 GPM½" MNPT
Any help you can provide would be appreciated.
Best Regards
Pathfinder Tags: 3-way dual shut-off valves
Location: Somewhere near BF, Arizona. ...seriously! ...we're that close.
Re: Wanted: 3-Way Dual Shut-off Valves Between Vessel and PSV
09/15/2008 11:18 PM
I believe the company Henry Valve makes what you seek. Call them with your specs.
We used to have them all over the Air Sep. facilities.
Cheers,
Don
There are people who make things happen, there are people who watch things happen, and there are people who wonder what happened. To be successful, you need to be a person who makes things happen.. Jim Lovell, NASA Apollo 13 Hero
09/18/2008 10:51 AM
Thanks Don. Henry Valve has three-way dual shut-off valve exactly I want, but they have no CRN# from Ontario, So I can not use it. I need search the market again.
Best Regards,
Lus
Register to Reply 2 comments
You might be interested in: Gas Valves, Industrial Valves, Solenoid Valves
