Previous in Forum: Wanted: 3-Way Dual Shut-off Valves Between Vessel and PSV   Next in Forum: Hydraulic Powerpacks
United Kingdom - Member - British
Electric Bike Motor
09/15/2008 11:02 AM
Hi,
I am making an electric bike, and bought a 12v battery for it. I was wandering if you can run a 24 or 36v motor from it. It is advertised as "excellent for a wind generator", and says that at 200RPM it will deliver 12v. I was wandering if I put 12v into it, would it work as a desperatley needed motor?
Any comment welcome
bondy111
Re: Motor
09/15/2008 4:10 PM
If it's a permanent magnet DC generator, it will almost certainly work as a motor.
A 24v or 36v motor will run off 12 v but it will take less current than at it's rated voltage and have much less oomph (technical term).
You could have 2 batteries and have them switchable between series or parallel for max speed or range?
Re: Motor
09/16/2008 11:11 AM
ok
thanks
bondy111
Re: Electric Bike Motor
09/16/2008 12:48 PM
That it might "work" is one thing, but for how long?
I cannot ever recommend using a generator as a motor or a motor as a generator, especially if it has brushes as the field will always slew with load and the brushes may well be in the wrong position and you will get really bad sparking and erosion of the brushes and commutator.......
Use a car wiper motor and gear it down as required. Use a simple PWM circuit for good speed control, I made one recently for about $2 with a 555, a MOSFET and a handfull of other components, it works great!! If you want the circuit diagram, I can send it to you, I found it on the web a long time ago......or search on the web using as a search word "555 PWM".
09/17/2008 12:56 PM
Will the motor be strong enough?
the motor will have a sprocket mounted on the pole, which will have a chain to the third gear on the front, and then the normal chain will go between the first and second gears.
Also, thanks for the advice, and if you could send it to me that would be great
Thanks
bondy111
Register to Reply 4 comments
Andy Germany (1); Bondy111 (2); user-deleted-1105 (1)
