Previous in Forum: Compressed air audit   Next in Forum: Design of Tubing
8 comments
Best Metal Hubs for Wheels
09/22/2008 11:45 AM
HI,
I'd like to know your advices about the strenght of steel/alloy material.I'm on the way to have my four hubs CNC matchined (I'm restoring a car) and I don't know which is the best material for the job.Iwas thinking to use 304 SS but someone told me that it's not so strong for the job, so I was looking for Ergal but reading the specifications sheet I've found that the SS has more than double resistance...
So, does anyone know which is the best and strong material for my hubs?
I don't want to see any sign of corrosion/oxidation for a long time...
Thanks in advance for your help.
Regards
Giorgio
Good Answers: 123
Re: Best Metal Hubs for Wheels
09/22/2008 6:27 PM
Are you leaving them unpainted? If so Use a high strength steel, and have them chrome plated. They could be polished first, or just plated over the machine work as it is. If you are going to add color to them, I would suggest cadmium plating first. That way if the paint chips when attaching the wheels are attached, there will be no corrosion under the wheels. Good luck.
Bob
09/23/2008 5:04 PM
be careful of hydrogen embrittlement, if electroplating.
also be aware that the higher strength steels are more notch sensitive.
If you always do what you've always done, You'll always get what you've always had!
09/23/2008 6:36 AM
Please, tell us more of the restoration that requires CNC hubs!
09/23/2008 1:57 PM
HI, thanks for your answers even if not specific to material..So, the restoration,
I have bought a Lotus Esprit S2.2 1981 in UK and I'm doing a nut&bolt restoration.
Every part must be new or renoveted where it's possible, the rear hubs are not available and the front are very expensive...but I can have these parts machined free...so I need only to choose the best material.
If someone is interested I have loaded my restoration photos at:
http://s303.photobucket.com/albums/nn145/ghe67/My%20Esprit%20restoration/?albumview=slideshow
Many thanks for your attention.
Giorgio
Good Answers: 97
09/23/2008 2:40 PM
What environmental factors are involved, is a corrosive environment; will the vehicle be on an island in an ocean, etc??
521 SS is a great material spec
09/23/2008 2:55 PM
Hi Bwire,
thanks for your advice.
....island in an ocean...?? uhmmm no, it's only the road salt that are frequently used in my country in the winter...so seeing that I'm doing a little masterwork I want a rust proof material.
I'm a little maniac...I know, but I will see regarding the 521 SS.
Thanks
Giorgio
Good Answers: 97
09/23/2008 7:03 PM
Okay great 521 is a specific grade and used when fatigue is and issue you may not find it easily.
A 17-4 is readily available and may service you well if a very brilliant finish were specified about 10 micron.
A mild vinegar and water mix sprayed on followed by a soft water rinse is a good corrosion prevention
Good Answers: 123
09/23/2008 11:54 PM
Vinegar and water? Where can I find a vineger and water solution? Perhaps I should ask my wife?
Bob
Anonymous Poster (2); bob c (2); bwire (2); sidevalveguru (2)
You might be interested in: Serial Hubs, Network Hubs, Oxidation Equipment
