Previous in Forum: Calculating Weld Strength   Next in Forum: Calculating Output RPM
AFBC Boilers vs. CFBC Boilers
09/24/2008 2:29 AM
Dear all,
please tell me what is different between AFBC BOILER & CFBC BOILER.
Good Answers: 58
Re: DIFFERENT BETWEEN AFBC& CFBC BOILER
09/24/2008 3:50 AM
One is Atmospheric and the other is circulating.
I see that you are new to this site - welcome. If you want to get the best from some great people on this site you need first to do your own research, (a google search for AFBC will get you a great deal of information) and then come back to this forum with a specific question. You will be amazed at how helpful some of these guys can be.
Good Answers: 68
Re: AFBC Boilers vs. CFBC Boilers
09/25/2008 12:37 AM
Hello pkartikeswar:
Check out this site. It details both kinds of boilers and residuals from them.
Hope this is useful
http://www.power-technology.com/contractors/boilers/thermax/
06/20/2010 7:15 PM
effeciency of CFBC boiler is more then AFBC boilers on part load. u may run boiler on even 25% load, Maintenance is less due to less contact od pressure parts by eroding flue gas, low NOX & COX , but refractory cost is much more high compare to AFBC due to quantity and quality also.
jitendra Chauhan
Sr. Er. maintenance ( Mechanical)
India Glycols Ltd. Kashipur ( Uttrakhand)
09/29/2010 3:09 PM
sir,
that explain useful for me. what mean by nox& cox
10/12/2012 12:37 AM
AFBC : Atmospheric Classic Fluidized Bed Combustion (AFBC)
CFBC : Atmospheric Circulating Fluidized Bed Combustion (CFBC)
1.Velocity:
AFBC = 1.2 m/sec to 3.7 m/sec
CFBC = 3.7 m/sec to 9 m/sec
2.Heat Transfer Surface:
AFBC = Heat is extracted within the the bed
CFBC = Heat transfer occer outside of combustion zone i-e Convection section, water walls and at the exit of the riser
3. Size of Coal
AFBC : 6-10 mm
CFBC : 6- 12 mm
4. Combustion Air Supply
AFBC : 3 - 5 psig
CFBC : 1.5 - 2 psig
Advantages of CFBC over AFBC
CFBC technology evolves from AFBC to overcome some of the Problems of AFBC
a). Better Space utilization for large Industrial units
b). Efficient combustion
c). Better SO2 capture
d). Better Techniques for Nox Control
e). Better temperature Control
f). More economical for Industrial application requiring steam demand more than 100 Tons/hr
g). Better for low garde Fuel with Low calorific value and high Ash content
h). Reduced Erosion of heat transfer surface in combustion chamber as surface is parallel to the flow contrary to AFBC
Thanks and Kind Regards
Aghvel Niazi
01/16/2015 2:11 PM
Please mail this info on From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
Register to Reply 6 comments
Aghvel Niazi (1); Anonymous Poster (2); babybear (1); mangalraj s hada (1); The Prof (1)
You might be interested in: Boiler Services, Industrial Boilers, Boiler Controllers
