Previous in Forum: AFBC Boilers vs. CFBC Boilers   Next in Forum: Building a Better Bagger
Calculating Output RPM
09/24/2008 2:52 AM
Hello all,
Can anyone tell how to calculate the o/p rpm for double end shaft drive connected to another shaft with universal coupling both end which in turn is connected to a flat belt pulley to drive the belt at 10 m/min i have calculated the power requirement which is 3hp. the distance of pulley center from drive center is 1700 mm..
Re: how to calculate output rpm
09/24/2008 4:26 AM
you may out the type of belt (standarts) or define friction factor and angle between pulley and belt. calculate coupling area after calculate tork on pulley use this information if you know shaft diameter you find neccesary rpm. if you know belt standart you have to use some charts to calculte rpm
Good Answers: 16
09/24/2008 8:56 AM
If you are simply looking for RPM, distance plays no part in the calculation.
Need to start with the motor or driver RPM, then just go one step at a time through your drive system.
Supply all the information and someone can quickly calculate it.
Driver RPM, all pulley sizes, gear reduction, etc
Good Answers: 97
09/24/2008 9:35 AM
A too short distance may shorten the arc of contact at the smaller pulley and may cause slip. but incorrect tension can do more damage.
I have hidden my trusted flat belt info to keep the younger generation away from dooming evidence and now I cant find it. My file 13 is also empty. The belt manufacturers may rather have the info to assist you.
Re: Calculating Output RPM
09/25/2008 5:51 AM
Circumference of the pulley is 3.4meter
Therefore for a belt speed of 10 m/min RPM = 10/3.4 =2.94 RPM.
09/25/2008 10:33 AM
You can find the answer in any of the books on Theory Of Machines.
As far your problem more data is required. You need the diameters of the pulleys on which the belt at 10m/min is running. Then use
Velocity of belt (m/sec)= ( pi * diameter of pulley in meters * N(rpm))/60
Then use the velocity ratio to know all other speeds
velocity ratio is Speed of driver * Dia of driver = Speed of driven * Dia of driven
Hope that solves your problem.
alperr125 (1); Anonymous Poster (1); garth (1); Hendrik (1); Tim in Mexico (1)
You might be interested in: Round Belt Pulleys, Pulley and Roller Lagging
