Previous in Forum: Energy Efficiency of Electric Injection Molding Machines   Next in Forum: Selecting a PSA for UHMWPE Film
Location: Globaly - very close to the southern most point of Canada
Good Answers: 12
Reducing Carbon During Brazing
09/24/2008 4:05 PM
I am brazing steel and stainless steel fittings and manifolds for pressurized fluid conveyance.
Currently there is an issue with build-up of carbon. Particularly inside where it is difficult to apply flux. We must grit blast after which is very labour intensive.
Does anyone know of a way to prepare the components to eliminate the carbon build-up?
Thanks
-why bother doing it wrong when it will be anyway.......
Re: Reducing Carbon During Brazing
09/24/2008 5:06 PM
Yeah I've had that problem before.Tell me what are you using? Oxy-Acetylene?What type of steel?I know you said Stainless fittings,is the other cast iron?or a high carbon steel? Skipper
Hope for the best,Expect the worse,Take whatever comes
09/25/2008 6:09 AM
Are you trying to braze to quickly with very hot flame? if so you are probably overheating your joint. I assume you are silver brazing not bronze?which requires a much higher temperature.
45% silver solder is best for a low temperature but there will all ways be some discoloration,use a neutral flame to keep carbon deposits to aminimum and or use propane it is much cleaner.
Good Answers: 58
09/25/2008 8:21 AM
You might consider flowing argon through the manifold and pipes during brazing to displace the air. That should eliminate the need for post-braze clean-up.
United States - Member - Member Hobbies - DIY Welding - New Member
Good Answers: 50
09/25/2008 8:21 AM
Go to this website:
http://www.lucas-milhaupt.com/htmdocs/brazing_support/everything_about_brazing/what_brazing_about.html
This is a good start. These people provide excellent support. If you don't see what you need here, call them. Excellent service.
And I do not own stock in the company...
Speak softly and carry a big stick.
09/27/2008 1:05 AM
If all else fails two possibilities,
TIG (GTAW) or use a Hydrogen Oxygen torch system (spendy but might have cheaper total cost).
Brad
garth (1); Skipper (1); standarded (1); U V (1); welderman (1)
