Previous in Forum: Friction Factor for HPDE Pipeline   Next in Forum: ASME Sec. VIII
13 comments
Designing a Contact Pressure Sensor
09/24/2008 8:31 PM
I am a mechanical student and i have to design this sensor. the sensor is used to measure the pressure between two surfaces, ie flanges of connecting pipes.
so i need help in typical pressure or force & area values between flanges of pipes. also any books and sites that may help in me finding a suitable design.
thanks,
Lomas.
Re: need help in designing a contact pressure sensor.
09/24/2008 8:50 PM
Hi there Lomas,
You may want to look into pressure sensitive film, I do not have the company name right now, but you can google it. The film will give a colour impression that can be analyzed, remarkable, really.
Mirco.
Mirco
09/25/2008 7:14 AM
thanks mirco,
i'll research it. i have an idea that if i get the pressure the bolts can withstand then i'll get the range of pressure where the sensor will operate. so i am lookin for a sensor that can be sandwiched between the flanges and operate like a strain gauge to meansure pressure. i doesnt have to be strain gauge, which is simple, but as a final year student i am limited in knowledge so i cant design micro sensors so it will have to be macro.
also anyone know where i can find a datasheet for the bolts used in connecting the flanges?
thanks,
lomas
09/25/2008 7:22 AM
Hi Again,
As for the bolts, look into the "Machineries Handbook", it should list shear strength and bolt grading etc.
Mirco.
Mirco
Re: Designing a Contact Pressure Sensor
09/25/2008 11:36 PM
Hi Lomas,
as suggested by Mirco for pressure sensitive films, refer the site www.sensorprod.com . In this site you will find the product "Pressurex",is a extreme thin film can be used for mesuring pressure with the color coding.
Regrads,
Gorde Sanjay
09/26/2008 8:20 AM
Just as a stab at a simple solution: try two metal foils with an insulating coating (oxide? paint?). Measure the capacitance change as the flange is tightened.
09/13/2009 8:59 AM
Gorde-
My name is Mike and I work at Sensor Products. Let me know if you ever need to discuss any ideas.
Thanks
-Mike-
mford@sensorprod.com
Application Specialist - Sensor Products, Inc.
Good Answers: 12
09/26/2008 4:55 PM
Google FLEXIFORCE. You will find much information on a sensor that I have used with great success.
09/26/2008 7:11 PM
thanks everyone...i'll check out the things that you suggested. if i need to know anything, i know where the experts are!!.lol
lomas
09/28/2008 2:54 PM
hey i checked out the pressurex product. but i believe that i forgot to mention one more thing. the contact pressure sensor must be electronic. so it will be used as a system to tell when the pipe is going to fail at the flanges. so i need to sense the pressure get a signal and condition, amplify etc and display the value to the user or to maybe feed into a control system.
but the important thing is to get a sensor that sense the pressure and output a signal. after that, there are alot of books out there that can help me with condition the signal etc.
thanks for you help,
lomas
11/21/2008 3:42 PM
Lomas-
I recommend you take a look at our Tactilus Sensors. They consist of a sensing element (modular), a data collection hub/up-convertor and software to display your readings in real-time. Contact me at mford@sensorprod.com
09/13/2009 9:00 AM
Lomas-
Let me know if you ever need to discuss this kind of technology.
-Mike-
09/13/2009 11:04 AM
ok thanks for the offer. but i got through. thanks for all the help people.
09/13/2009 11:08 AM
sorry the Guest comment above was mine.
Register to Reply 13 comments
Anonymous Poster (2); esbuck (1); Lomas (4); MFord (3); mircoconsultant (2); Snave (1)
