I made a "compound" parabolic solar cooker for about 30 dollars inclucing the cooking pot.
I tested it a few weeks and was disappointed to discover that it only dilivered about 200 watts of heat into the food. (It has almost a meter of collector area)
Then I compared it with my 80 dollar 15 watt solar panel.
the panel also needs a 30 dollar charge controller and a battery to store the power (they recommend deep cycle which are over a hundred dollars.
If I just leave them alone without moving the dish, it collects 200 watts for 3 hours per day.
How much energy will the 15 watt panel collect? Potentially up to 12 hours at 15 watts if it is tracking. Which is almost equal to 1 hour of collection with my solar cooker!
But it is passive so it will not collect as much as that!
How much will it collect in the day if mounted correctly?
When you do this comparison, you wondor why people are investing so much money in solar photovoltaic when it is clearly not yet efficient enough to make economic sense.
In my view, the money would be far better spent on solar hot water systems.
Brian
