Previous in Forum: Chamfer Gages   Next in Forum: about pqr of tube to tube sheet
PWHT TIME
09/27/2008 10:55 AM
How we can calculate the PWHT soaking time for carbon steel PTC (thickness 40 mm ) ? Acccording to ASME code
Re: PWHT TIME
09/28/2008 4:05 AM
At first, we have to define the specification (type & grade) of that carbon steel material. Suppose we have a carbon steel material with P-No. 1, Gr. Nos. 1, 2, 3:
According to ASME Code, Section VIII, Div. 1, Para. UCS-56 and Table UCS-56:
• Normal Heating Temp. : 1100 oF (595 oC)
• Rate of Heating : ≤ 400 oF / hr (222 oC) divided by thickness in inches
• Rate of Cooling : 500 oF / hr (280 oC) divided by thickness in inches
Heating time = (1100-70) oF /[(400 oF/hr) (40 mm/25 mm)] = 1.61 hr (1 hr & 40 minutes)
Min. Holding Time = 1 hr / inch (25 mm) = (1 hr / 25 mm)(40 mm) = 1.6 hr (1 hr & 40 minutes)
Cooling time = (1100-70) oF /[(500 oF/hr) (40 mm/25 mm)] = 1.29 hr(1 hr & 20 minutes)
Re: PWHT TIME
05/30/2009 6:57 AM
Dear Sir,
What is the effect of increasing the soaking time for carbon steels beyond 1hr/1 inch thk.
Regards
P.S. Moorthy
Re: PWHT TIME
05/18/2010 10:54 PM
i con't able to understand can you please explain me in any simple way plzzzzzzzzzzz
how can i calculate the heating,soaking&cooling timing for PWHT
Re: PWHT TIME
09/30/2008 9:07 PM
Dear vishnus_2184,
I'd like to know your opinion about my post #1, is it valuable to you? or not enough?
Re: PWHT TIME
06/26/2009 7:09 AM
certainly yes
thank you very much & expecting lot more from you!!!!!!!!!!!!!!!!!!!1
Re: PWHT TIME
05/19/2010 12:18 PM
See the following PWHT-Example in PDF format.
Re: PWHT TIME
06/26/2010 1:57 AM
thanx !!!!!
Register to Reply 7 comments
Abdel Halim Galala (3); Anonymous Poster (2); vishnus_2184 (2)
