Previous in Forum: DIY Lead Acid Batteries for Home Standby Power   Next in Forum: Stator End Winding Vibration Monitoring Program
8 comments
Micro Geared Motor
09/28/2008 12:32 AM
I am attempting to find a mico geared DC motor with specific requirements; is there a website where I can post this? I have tried through Google but seem to become bogged down in all different various products and when I request info via e-mail,l seldom receive a reaction.
Pathfinder Tags: Micro Geared/Servo Motors
Re: Micro Geared Motor
09/29/2008 8:50 AM
Try Faulhaber. They claim to have the smallests DC-motors.
Rik.
09/29/2008 11:18 PM
Thanks, will report back!
09/29/2008 9:53 AM
what size? what purpose? do you need a few or a lot!
curious.. i have searched lots of them myself, and they are .. not easy to find..
plug a voltage into your search if you know what you want to work with and you might get a few good hits. also, search gearhead motor instead of just geared.
that should do it?
09/29/2008 11:21 PM
Thank You, will do the Voltage
09/29/2008 9:58 AM
09/29/2008 10:07 AM
Hi Sungun
I have recently received some 12v sample motor & gearbox from iris@kindlymotor.com, they are quiet and low current draw. My original request was through Global Sources (Ad top right hand of this page, GlobalSpec). They vet their suppliers so you stand a better chance of a reply. The normal procedure is the company will supply 1 or 2 samples and you pay freight, so you need to get an account with FedEx or similar. You need to show some credibility, such as have a web site, company name etc. Good luck.
Tony
The nice thing about Standards is there are so many to choose from.
09/29/2008 11:26 PM
Thank you Tony, wil try Globalspec and iris and report back to you!
Belgium - Member - New Member
Good Answers: 21
09/30/2008 6:05 AM
For a few years, I used very small motors with an
- output shaft diameter : 0.8 mm
- diameter motor body : 6 mm
- output torque 0.157 10E-3 Nm
- voltage 4.5 VDC
- speed 20 000 RPM
associated gear,
- output shaft diameter 1.5 mm
- gear housing diameter 6 mm
- reduction i= 854
- 5 stages planetary gear
that was very small
I "ll will look up the model and type.
Register to Reply 8 comments
Anonymous Poster (1); JE in Chicago (1); R.v.d.Heijden (1); rudy.leurs (1); Sungun (3); Tonymech (1)
