Previous in Forum: How to bake a potato   Next in Forum: Re: Rollingstock industries
22 comments
Storage Tank Explosion Overpressure
09/28/2008 11:50 PM
Dear All, i would like to consult your opinion on one my recent assignment.
Initially the storage tank is used to store biodiesel cargo for shipment at terminal located nearby a harbour. The cargo was hauled off and one week later; without clean-up on the tank; it was re-used as the client wanted to store the same product. Prior to bulking, it was subjected to nitrogen purging process.
Normally N2 purging requires approximately 11 hours to reach the required oxygen level (in percentage) within the tank. On top of the tank only the bleeder and the pressure vacuum relief valve were opened. There are 2 bulking lines; 4 inch & 8 inch. The former is used to purge N2 while the latter was closed.
About 1 hour and 30 minutes later, the roof of the tank rupture and the tank shell on the top section buckled on one side.
It was understood that this was a case of overpressure but what could be the contributing factors leading to such incident? Post incident assessment revealed the PV relief valve is functional when tested on other similar storage tank.
Please advice.
CR4 ADMIN: Deleted Images
Good Answers: 140
Re: Storage Tank Explosion Overpressure
09/29/2008 7:54 AM
Are you sure the failure mode was pressure? The deflection "inwards" on the tank side walls indicates a negative pressure event. Just an idea...
09/29/2008 8:28 PM
The incident happened when the tank was empty and N2 gas was supplied in through the bottom 4' bulking line. Therefore, it could not have cause negative interbal pressure. The buckling damage on the circumferential shell on the top section was as such due to the "pulling in" effect by the bent metal trusses supporting the cone roof from within when the roof was pushed upwards due to the event of overpressure.
Good Answers: 19
09/29/2008 7:25 PM
How is N2 provided, and how is it admitted into the storage tank?
At what temperature and pressure is N2 stored and admitted into the tank?
How is this process controlled?
09/29/2008 8:43 PM
N2 gas (from pump house) is supplied through piping that was connected to the tank via the bulking line.
Temperature is not taken into consideration as the tank was empty and due to the fact this was a purging process. The pressure supplied was at approximately 6-6.5 bar but the flow rate was unknown as this was a manual process (not controlled by automatic devices) in which the valves involved were opened into a certain degree (say quarter, half, three quarter or full). The N2 2" line was opened half while the 4" bulking line to the tank was opened quarter. On top of the tank, the 1" bleeder was fully opened while the PV relief valve tested to be functional when installed on a nearby tank.
As mentioned earlier the process was controlled manually. The concept is to purge N2 into the tank to displace air until the desirable oxygen (%) level is reached. Therefore, the operator will go up to the tank roof to measure the O2 level using a special device. When the desired O2 is reached the purging process will be stopped.
09/29/2008 10:29 PM
think that inside pressure in much less than atmosphere... It supposed that the PV relief valve should be closed (or more close-open ratio), rite?
09/30/2008 2:02 AM
The operator went up to the tank to check the PV relief valve was functioning properly right after the purging process started. According to him, it was behaving properly with the intermittent release of excessive pressure ( when internal pressure exceed ~25mmbar).
09/30/2008 1:53 AM
Have you considered temperture differentials? in particular if the N2 was still very cold or liquid, once in the tank it would expand rapidly, causing the pressure to rise very rapidly, far in excess of the actual flow in. The flow through the reliefs would be woefully inadequate and the tank would overpressure. Everything would look fine when you shut down as the relief valves and new cracks would relieve the pressure of the expanding gas. Leaving normal pressure in tank and valves that work perfectly.
Good Answers: 123
09/29/2008 11:10 PM
Ft Lauderdale water department had a leak in a similar water tank. the water ruptured the wall of the tank at the bottom. The weight of the water above the leak was so great that the flow of water was so great that the top corner of the tank was sucked inward from the negative pressure inside the tank. It looked like yours, only worse.
If you are sure that it was over pressure, then compare the flow rate of the bleeder valve and relief valve versus the volume going in.
But I would bet on suction damage.
Bob
09/29/2008 11:42 PM
The accident is a deformation due to overpressure, and not a buckling resulting from a vacuum. The overpressure makes the topped cone to enlarge outside, and due to the high strength of the weld of top angle-to-shell, the higher resulting forces on the top cone pulled down the weakest course (upper course is the thinnest) which causes that deformation towards inside of the tank, which looks like buckling.
The same accident happened at our workshop during hydrostatic testing of a horizontal vessel equipped with a flat heads, the over pressure makes the end of courses adjacent to the flat heads to be deformed into inside the tank, looks like buckling, while the flat heads deformed looks like an elliptical to outside.
09/30/2008 1:10 AM
Were there any flame arrestors installed with the PV vents? If so, were they not partially blocked? Also check the sizing of both the PV vents and the emergency vents for the worst case. This could be maximum nitrogen flow i.e. all supply valves fully open or fire case.
09/30/2008 1:53 AM
No flame arrester on the PV relief valve model and none were installed on it. The PV relief valve on the damaged storage tank was removed and installed on another tank for testing; afterwhich showed no indications of malfunction or complete/partial blockage. We suspected the N2 flow as well but we also concern if the PV relief valve had complete/partial blockage which could have been cleared during the mechanical explosion overpressure. Is it possible for the PV relief valve to choke at the first place?
09/30/2008 1:58 AM
Thank you Mr Abdel for correcting the terminology. Based on the operation conducted, our company is sure this was not a case of implosion; but rather it was an event of overpressure. Our concern is what could have gone wrong during the purging process that contributed to such occurrence. And what can we do to prevent such incident from happening in future? Kindly advice. Thank you all.
09/30/2008 2:36 AM
Dear keverne,
Actually, it is an overpressure during purging of N2, and not an explosion, and this may be due to:
a. Bad operation resulting from closing the outlets of N2.
B. Improper condition of breathing valve(s).
c. Pumping a huge bulk of N2 over the rated capacity of flow rates of the outlet(s).
09/30/2008 3:05 AM
Dear Mr. Abdel,
Sir you're right that the term "explosion" is misused here. May I asked if the situation should be termed "mechanical explosion" resulted from increased internal pressure within the storage tank exceeding the maximum pressure limit thus overpressure?
And what are the common improper condition on the valves which could have led to such incident?
Thank you again for your input and response.
09/30/2008 9:21 AM
Dear keverne,
The condition is just a Deformation due to Overpressure, and can be called an Over Pressurizing until Bursting. We used to use term Explosion only if an actual explosion occurred due to fire.
All valves and instruments assembled to the tank must be tested, inspected, and calibrated regularly in accordance to the related codes and standards and the recommendations of the manufacturers.
09/30/2008 1:16 PM
"...what can we do to prevent such incident from happening in future?..."
Suggest a pressure regulator on the N2 line valve into the tank. It's got to be cheaper to protect the tank than to repair/replace it.
09/30/2008 9:06 AM
Due to the large amount of N2 used and the rate as which it was being charged may have provided a cold nitrogen stream to the tank. With the ambient temperature being elevated, the cold nitrogen could have expanded and exceeded the discharge rate.
09/30/2008 9:24 AM
The air had a certain amount of humidity in it. The cold N2 caused it to condense out creating a negative pressure and the tank caved in. There should have been a functional vaccum breaker as well as a pressure relief valve. It would only require a small vacuum to damage a tank or pressure vessel in this way. I have seen similar things from my oil refinery days usually after "steaming out" a vessel.
Ed "FuzzyE" Kedz - for some unknown reason I am unable to log on.
Fans of Old Computers - Vector 1 - New Member
09/30/2008 1:50 PM
Normally N2 purging requires approximately 11 hours to reach the required oxygen level About 1 hour and 30 minutes later, the roof of the tank rupture and the tank shell on the top section buckled on one side.
Normal operation takes 11 hours and you reached it in 1 hour 30 minutes.
Sounds like you rate of fill may have been a bit excessive?
size of Relief valves may need to be increased to match your input.
Branson
"Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover." Mark Twain
Good Answers: 12
09/30/2008 5:35 PM
You make the statement that the pressure relief valve was tested and found to be functional. For the pressure relief valve to provide the desired protection, it must be sized for flow rate as well as pressure. I am guessing that the valve cannot support the full flow rate of the purging gas.
10/03/2008 12:12 AM
just an additional insight . . .
i've read some articles, regarding some major accidents, and most of them are cause by human error. . . since your purging operation was not totally automated and it is manually operated, better check your staff, specially the operator, if they were as alert as they should be during operation . . . example: the probability of reading a magazine while in operation, or talking to someone during process. or the possibility of not being attentive/horseplaying . . . i really believe that part of every engineers duty is safety and alertness . . . . .
but this is me . . . just an opinion and no offense intended
Good Answers: 15
10/10/2008 7:15 AM
I know nothing about this particular subject. But I was wondering why the tank was being filled with N2 in the first place. If I understand correctly it was to remove moisture from the tank.
You stated that the tank was not cleaned between fillings. Did the moisture come from condensation after the tank was emptied?
Was there really that much water in the tank that you had to use N2 to purge it? Seems to me that there shouldn't have been that much water in it to effect the fuel. I know that underground fuel storage tanks eventually contain some water after they've been in the ground a few years. But even then considering the size of the storage tanks there usually isn't enough water to effect the fuel. There is probably more water ratio wise in your trucks fuel tank than there would be in a large storage tank.
Thanks for putting up with my uneducated ramblings.
scotchdrnkr
Register to Reply 22 comments
2ndthot (1); Abdel Halim Galala (3); Anonymous Poster (3); bob c (1); BRANSON (1); dark_riderblade (1); EnviroMan (1); keverne (6); Kief Hess (1); North of 60 (1); Ried (1); scotchdrnkr (1); Snave (1)
