Previous in Forum: Junction Box Rules   Next in Forum: Temperature sensitive valves
energy tester
09/30/2008 7:48 AM
Sir
I am electronic mechanical servicer and i am looking for instrument to test
for e.g. to check a battary from 5amps to 150 amps and a transformer
to 3 amps 6 amps direct on plus and minus without load that how many
amps remaining in the battary and transfomer after dc current i have no
idea which i can get please help me the correct instrument
Re: energy tester
09/30/2008 2:58 PM
If you want to test batteries and transformers separately under load (such as finding out if a battery is charged up or in good condition, etc) then you are probably after a battery load tester (or similar).
If you are after just checking current (A) with the batteries and transformers connected up to an existing load, then you are after either an ammeter (basic unit), clip-on ammeter (allows you to measure current without having to disconnect the wires) or multimeter (almost all have a built-in ammeter function and can also measure voltage and other useful things).
Try a basic google search for "battery load tester", "ammeter" and "multimeter". Wikipedia probably has some good information to help you get started in choosing exactly what you need.
Reply to Forum Thread
You might be interested in: EMI and RFI Testers, Hardness Testers, Ring Gages
