Previous in Forum: Problem with McAfee Antivirus   Next in Forum: Laptop Problem - COM Port
ABB Rapid Programming
09/30/2008 9:32 AM
Hello,
I'm new rapid programing. I currently have an laser engraver mounted to a LRB 2400. I have the robot inter-phased to the laser engraver via I/O signals. After every layer the laser lases I'd like to lower the engraver head linearly in the Z direction. The problem I'm having is, I cannot seem to find away to lower the head from it current position. I'd like to make my robot target command variable. (I.e P1, P2, ...)
Is there a way to make a command like:
MoveLOffst(currentPosition,0,0,-5) (this command won't work of course, but I'm trying to feather explain my problem)
Any help would be appreciated
Thanks,
Matt
Re: ABB Rapid Programming
09/30/2008 9:39 AM
I should also add the controller is an S4
10/02/2008 12:57 PM
Matt,
If you want to use a varible it would look like this
PERS num nZmove:= -5;
MoveL Offs(pLaser,0,0,nZmove),v1000,fine,tLaser;
If this doesn,t help? Let me know.
Tony
11/03/2008 11:49 PM
What is the meaning of 'PERS' (PERS num nZ....)
02/10/2011 9:31 PM
I have a question about ABB RAPID code...
I really don't understand about := means....
is that same with != from C programming??
and -5 is just number ? or special code?
11/04/2008 8:16 AM
PERS means persistant the number will stay in the memory if the robot is powered down.
CONST is constant the program is not allowed to change the number.
VAR is variable will change to zero when robot is powered down.
Hope this helps.
09/05/2009 7:05 AM
Hi
I guess you want to move the laser in tools coordinates.
To do that you need to use command RelTool.
Like this:
PERS num Zmovement:=-5;
robtarget:=currentPosition;
MoveL RelTool(robtarget,x,y,Zmovement), v100, z1, tLaser;
This should move the robot in the direction of laser beam. No matter if its facing sideways or upward or any other direction.
/Daniel
09/05/2009 7:11 AM
Hi again
ofcourse you need to make a loop to increase the movement -5 each time, or the command only do the movement 1 time.
/Daniel
Anonymous Poster (4); ChargerRT (2); freshjive (1)
