Previous in Forum: Descaling   Next in Forum: MDF Powder Coatings
Distillation Curve
10/01/2008 7:29 AM
I have calculated distillation curve using these methods for my petro components D1160 volume basis, D2887 Wt basis, D86 Volume basis and True boiling point curve. The curves are not monotonic, the temperature for 25%, 30%, 35%, 40%, 45%, 50% are less than the temperature of 20% vaporization.
The results: 0% - 8.9K, 5%=66.79K, 10%=194K, 15%=269K, 20%=281K, 25%=254K, 30%=215K ...
Is this correct? If not where can i get correct results, can you suggest some material where can i find some correlation to predict correctly.
Thanks.
Pathfinder Tags: Distillation
Re: Distillation Curve
10/01/2008 11:41 PM
Consider that you might have DCPD and/or mixed dimers that crack under distillation conditions, lowering the overhead temperature, because the monomers are much lower boiling than the dimers. This is typical behavior for a mixture from a cracker.
You can't manage what you can't measure.
