Previous in Forum: Messed up household electrical   Next in Forum: Measuring High Voltage Electrostatic Currents
8 comments
Plug and Receptacle for Hazardous Areas
10/01/2008 11:14 AM
Hello,
I was wondering if anyone on here has heard of a UL listed plug and receptacle rated for use in a class 1, div 1 areas. This is for a pumping application in a wet well.
I found a connector that is CSA listed for Class 1, div 2, but am unable to use it since it is not appropriately rated or listed.
Thanks for you help,
Mark
Re: Plug and Receptacle for Hazardous Areas
10/01/2008 2:24 PM
There are few companies that do this. Vantage may be your best bet (and it's in the US).
http://www.vantagexp.com
Don't be surprised at the price tag, hazardous area plugs and sockets are rather expensive.
10/02/2008 11:59 AM
Thanks for the tip, I have contacted Vantage and am awaiting their response. I haven't worked with their products before, hopefully this does the trick.
10/01/2008 3:45 PM
Crouse Hinds makes alot of hazardous location electrical supplies.
Here's a link to exactly what you need http://www.crouse-hinds.com/catalog/PDFS/01007to01009.pdf
This is good for class1 div1....
10/02/2008 11:55 AM
I would love to use Crouse-Hinds since they're a local company. But after talking with fellow coworkers here, it sounds like we haven't had good success with these connectors in the past, I believe because of corrosion issues.
10/02/2008 11:47 AM
Hard wire it. That is the best way to do this.
10/02/2008 11:52 AM
Typically, this is the approach we take. But the client asked for a method which would allow for easier maintenance on the pumps. Seal-off fittings prohibit easy removal of the pumps from the wetwells.
Good Answers: 61
10/02/2008 12:47 PM
Hubbell/Killark has similar equipment, both metallic and non-metallic enclosures, Class 1, Div. 1 and 2. Here's a link to their catalog search page for hazardous location receptacles.
12/19/2008 11:18 AM
You can also find them with R STAHL thru the following link...
http://www.rstahl.com/home/usacanada-products-and-systems/nec-and-cec-electrical/plugs-receptacles.html
Register to Reply 8 comments
jack of all trades (1); pwr2thepeople (1); ral412 (1); sparkybust (1); thompsm (3); Ydobon (1)
You might be interested in: Receptacle Testers, Plug Valves, Plug and Pin Gages
