Previous in Forum: please help me   Next in Forum: Northern wisconsin grain bin
Basic Wind Speed in Saudi Arabia
10/05/2008 10:44 AM
Hi fellow Engineers,
I am making a structural design calculations for a composite structure using reinforced concrete and steel shapes. I want to incorporate the wind factor on the design. Can you help me provide the applicable Basic Wind Speed for this location (Dammam, Saudi Arabia) and the applicable wind formula other than the traditional old formula Force, F = A x q x Cd where q = 0.00256V² .
Re: Basic Wind Speed in Saudi Arabia
10/06/2008 1:38 AM
Look to the British Standards or those common in Qatar or Dubai
Generally 140 kmphr and remember about 5.5R for seismic
Tom
10/06/2008 2:10 AM
My dear Junos2008,
In the following CR4 Thread Calculating Wind Resistance, you will find more data and details in calculating the wind load as per code ANSI/ASCE 7-88 & ANSI A58.1-82. For wind speed in Saudi Arabia, I prefer to use the worst case which reaches about 160 km/hr.
10/06/2008 4:54 PM
Checkout the installer and ask them of your specifics.
Minnkota turbine a first for 'Saudi Arabia of wind' http://www.wapa.gov/es/pubs/esb/2002/02Apr/apresb6.htm
A huge crane helped to install Minnkota Power Cooperative's 25-ton wind turbine and 230-foot-tall tower.
On Jan. 25, the state of North Dakota and Minnkota Power Cooperative took a big step toward living up to the label of "the Saudi Arabia of Wind Energy"--and toward spurring economic development.
More than 300 people gathered for the commissioning of the state's first commercial-scale, utility-owned wind turbine. Located six miles east of Valley City in southeastern North Dakota, the 900-kilowatt wind turbine should produce 2.5 million kilowatthours of energy each year. That's enough to power 200 to 300 homes.
Speaking at the dedication, North Dakota Senator Byron Dorgan said, "We have the potential--right here in North Dakota--to lead this nation in wind production. The wind experts call North Dakota the Saudi Arabia of wind power, and Minnkota Power Cooperative is taking the first important step in our state."
Minnkota launched its Infinity Wind Energy program in response to requests from customers. The project received strong support to get it off the ground, with about 2,100 customers of Minnkota-associated cooperatives and municipal utilities subscribing to the program. Minnkota owns, operates, and maintains the turbine for its member cooperatives and members of the Northern Municipal Power Agency, which represents 12 municipal utilities in North Dakota and Minnesota.
Subscribers agree to pay an extra $3 per month for each 100-kWh block of wind energy they buy. The premium covers the higher cost of wind energy when compared to conventional power sources. Minnkota will also receive state production incentives that help lower the cost of wind power.
The turbine will operate when the wind speed is between eight and 56 miles per hour. Wind speeds below that range aren't sufficient to generate electricity, while speeds above the range could damage the turbine's blades. Minnkota estimates that the turbine will generate electricity an average 30 percent of the time.
The turbine sits atop a 230-foot tower and weighs 25 tons. Each blade measures 85 feet long and weighs 5 tons. Wanzek Construction of Fargo, N.D., used a huge crane to erect the structure. And it wasn't the only North Dakota company to benefit from the $1 million project.
LM Glasfiber of Grand Forks fabricated the turbine blades. Besides fabricating blades for Minnkota's project, the plant also provided blades for Moorhead, Minn., Public Utilities' Capture the Wind program, and other wind-energy projects from New York to California.
DMI Industries of Fargo built the tower. DMI used to manufacture farm implements for the sugar beet industry, but switched to wind-turbine towers. The company employs about 110 people.
North Dakota's agricultural community could also benefit from future wind-energy development. Farmers who allow wind turbines on their land can receive lease payments of about $2,000 annually. The Des Moines Register reported that one farmer near Storm Lake, Iowa, hosts 16 turbines on 15 acres of his farm, earning about 10 times more from the leases than he would have earned growing corn.
Why is North Dakota such a promising site for wind-energy generation? According to the National Renewable Energy Laboratory, the state has enough wind resources to produce 1.2 billion kilowatthours of electricity annually. The entire state is a Class-3 wind resource, meaning the wind blows across North Dakota an average of 14 to 15 miles per hour. Parts of the state have Class-5 winds (16-18 miles per hour).
These sustained wind speeds provide North Dakota with the most potential for wind-energy development in the United States.
Web Sites:
Holy Cross Energy: http://www.holycross.com/
Xcel Energy: http://www.xcelenergy.com/Environment/Environment renewable.asp
Serving The Public Better The Electric Vehicle Free Conversion Foundation (EVFCF)
10/07/2008 3:47 AM
You can use ASCE Wind Lad Calculation 'Simplified Procedure' but with limitation. The formula you stated above is the 'Analytical Procedure' which is you can use for all building and other structures.
Hope this helps.
acres
02/11/2009 3:11 AM
Hello; ARAMCO publishes basic Wind Speed and all other meteriological data annually. I cant attach this data file here in this mail .. send me email I shall attach you the Met Data file from Aramco for your help. Fareed_siddique@yahoo.com
11/04/2009 12:04 PM
The following file was send by our friend Fareed Siddique concerned with wind speed and other meteorological data at KSA, published by ARAMCO: Saudi_Arabia_Meteorological_Data.
11/04/2009 5:23 AM
Hello there
Kindly send me your email ID, I can send you the said Saudi Arabian Wind Load data. My email is fareed_siddique@yahoo.com
Mohammed Fareeduddin
B.E; M.E Civil Strl.
Member of:
ACI / AISC / TIA-EIA222 & ASCE
http://www.linkedin.com/in/mohammedfareeduddin
Register to Reply 7 comments
Abdel Halim Galala (2); acres (1); CharlesJones (1); ctwiliams (1); Fareed Siddique (1); Mohammed Fareeduddin (1)
