Previous in Forum: Cable Gland and Low Voltage Control Cable 0.6/1 kV   Next in Forum: Calculating Network Impedance
Load Flow and Short Circuit Calculation
10/07/2008 2:00 AM
Can somebody suggest a software program for load flow analysis and short circuit calculations besides 'etap'. Are there any free programs available on the internet
Good Answers: 213
Re: Load Flow and Short Circuit Calculation
10/08/2008 1:20 AM
Check out "ATP-EMTP". This may be what you are looking for.
http://www.emtp.org/
United States - Member - Member Engineering Fields - Power Engineering - New Member
10/08/2008 9:34 AM
I use Easy Power, but I've also done some calcs with pencil and paper. If you're just doing a few branch circuits its not that bad. There are a few papers and guides in the public domain that would guide you in making the calcs if you don't have any hard reference material.
10/08/2008 9:45 AM
>> available on the internet[?]
A suggestion of a program for load flow and short circuit analysis is much more complex than just a link to a web site. While there are some 6 to 8 programs out there, they have significant differences in their strengths, weaknesses, and features.
Some of the questions you need to consider are:
  • Voltage(s) to be modeled
    • nominal voltage,
    • on a per-unit basis
  • Need to perform
  • Load flows
  • Fault-current calculations
  • Over-current protection coordination
  • Harmonic analysis
  • Loss Analysis
  • Voltage drop Analysis
  • Reliability analysis
  • Transient analysis
  • Motor Starting/flicker analysis
  • Capacitor analysis
  • Maximum busses
  • Multiple sources for wide area studies
  • Loop and/or radial analysis
Will you build the model in the software by hand, or from an existing data base (i.e., a GIS system), and will you need to integrate the software with any other data bases?
There are "free" programs out there, like ATP-EMTP and DSS, and programs that will cost you thousands of dollars.
A partial list of other programs is: EMTP-RV, CYME, Milsoft, PSCAD, Easy Power, SynerGEE, DlgSILENT, PTI PSS, PSLF, ...
10/08/2008 11:44 AM
Investigate EDSA. They have a full suite of software.
Ireland - Member - New Member Engineering Fields - Energy Engineering - New Member
10/08/2008 6:46 PM
Talk to Schneider about EcoDial. Search the forum.
I love deadlines; I love the whooshing sound they make as they pass by. - Douglas Adams
02/12/2013 12:40 AM
Try SKM PTW - DAPPER Only $1,500/-(50bus) & $2,995(100bus) with Comprehensive SC Analysis.
If you need, I can do it for a reasonable fee with detailed report writeup & inference. I have a licenses SKM PTW (Version 7.0)
Anonymous Poster (1); BabyGuinness (1); cwarner7_11 (1); jconn_ETEC_05 (1); KITES (1); OscarOfWaldo (1)
You might be interested in: Circuit Breakers, Gas Flow Meters, Flow Meters
