Previous in Forum: Steam Flow and Steam Temperature   Next in Forum: Optical Displacement Measurement Via Shadow Moire
8 comments
Studs, Bolts, Flanges and More
10/07/2008 12:05 PM
please answer the following querries:
how can we check the MTC of a material against the material that is being brougth to the site ? QA/QC related query
what does mean by M in stud and bolt like M20 plz explain it ?
the falnge has an abbreviation of class 150 wht does this calss represent and wht is its unit ? is it psi ?
why we mostly do sand blasting on standard Sa 2.5 ( near to white metal) why not we go to Sa3.0 ( white metal) is there any specific reason for that?
why we use jacket pipe ?
should we coat with primer after sand blasting the inside surface of first shell of oil storage above ground tanks ( dia 45m height 20m). we wil do the outer paiting and it is mention in contract with client. is it necessary to do from inside ? if yes than wht is the reason behind it ?
regards
M.Faisal Siddiqui
BE MECH.
Good Answers: 19
Re: answer them plz
10/07/2008 12:54 PM
Mr.Faisal please varify as to the complete name & location & type of plant (Cement/oil/Sugar etc.)you are employed with.
Your questions coming in seems that you have recently joined and want to get all answers from people around the world to make an impression to your immediate Boss or your Seniors are just willing to teach you.
Or these are part of your course? or thesis?
Good Answers: 19
Re: answer them plz
10/07/2008 1:04 PM
Continuation -
I also see you have Forum Threads "Short Answer Plz" & "Oil Storage Tank".
Faisal - What are you? Did you shoot your head off prior your appointment that you now find yourself in a place where you need all the quick answers?????
On Oil Stroage tanks i referred Mr.Abdel Halim Galala who gave you aqn excellent description. Please first learn to thank him for this!
Good Answers: 19
Re: answer them plz
10/08/2008 2:55 PM
Continuation again - I see you are in a Thread "Pipeline" too!
Re: Studs, Bolts, Flanges and More
10/08/2008 4:20 AM
Faisal,
If you are an engineer with a degree in the subject, you should know the answers to most of these questions.
If not, a good place to start is to invest in a copy of Machinery's Handbook or any good text book on the subject. Most engineers I know invest in a copy sooner or later.
Have you read ANY of the documentation supplied to you by your client? Do you know what a specification is? If so, you should have one for the equipment you are building - READ IT AND THE CODES, STANDARDS AND SPECIFICATIONS TO WHICH IT MAKES REFERENCE. Then make sure you understand them. Go and talk to your supervisor about what you don't understand. If he's competent, he should be pleased to train you or agree a course of action to clarify matters, which often means going back to the client and asking for clarification.
If you're scared to ask - GET OVER IT - until you do, you are potentially dangerous to the public at large.
I have suggested before that some of those who post to this website should familiarise themselves with using Google or another Internet search engine - you would find the answers to some of your questions there.
Whilst I would always encourage engineers to ask questions when in doubt, remember that the first person you should be asking is your immediate supervisor. Did you ask him? IF YOU DIDN'T, WHY NOT? We'd all be interested to know the answer.
Owen.
Engineering Fields - Mechanical Engineering - Member Engineering Fields - Piping Design Engineering - Member United Kingdom - Member - New Member Technical Fields - Education - New Member Popular Science - Cosmology - New Member
10/08/2008 4:48 AM
Faisal Siddiqui,
The 'M' in M25 for example simply means that it is a metric bolt you are working with. i.e. M25 means you have a bolt with a 25mm diameter.
There should be some other markings on the head of the bolt. This is just the material of the bolt.
When you say 'Class 150' you are generally talking about the maximum working pressure of the pipe in PSi I believe.
This is an ANSI pipe you are using - they normally come in classification sizes 150, 300, 400, 600, 900, 1500 and 2500. This is an IMPERIAL size pipe - i.e. everything measured in inches so I am a bit confused as to why you are using metric bolts.
For example, and ANSI Class 150 pipe with pipe size 14" (the OD of the pipe) uses 12 of 1" bolts. 1" being equal to 25.4mm. Where these seem to be the same in dimensions, they will vary slightly from each other which may affect your bolt stress and torque levels.
I cant answer your questions regarding sandblasting unfortunately but I can probably answer any other questions you have regarding the pipe/flange/gasket/bolts etc. I will subsribe to this topic to be alerted of any future posts.
Hope this information has helped you.
You mentioned MTC of a material - can you explain what this is as I may be able to help you with it.
Kind Regards
Kev Brown
Hobbies - DIY Welding - pipewelder
10/14/2008 11:13 AM
Hello, I give you a GA for your reply being that you tried to help and answer his questions and didn't merely tell him he should not ask or should have already known the answers. Also I think he means Material Test Certificate by saying MTC. I would have called it MTR for Material Test Report but It could be different where he is from?
pipewelder
pipewelder
10/09/2008 10:27 AM
I have just received a message in my Inbox from Faisal Siddiqui. I am not sure how I got this as I am not in the distribution list although it could have gone to all in Mech Engineering or such.
I feel what I need to say should be said here though and not in a personal message.
I cant understand all the bad feeling towards this person. He is obviously wanting to learn as he has recently graduated.
Think back to the times not long after graduating yourself, I bet you asked questions to friends, peers and superiors. If this is true about this guy and he has not got a lot of information or help available to him then this place is the next best place to come. There is a wide variety of skills here so any question should be able to be answered.
At the end of the day, this guy needs help on a few subjects so has asked a question. Would you lambast any of the more established members on this forum if they asked a question - 'No' is your answer, no you would not.
If we manage to help him do his job then great. If he then goes on to help others then even better.
NOTE TO FAISAL SIDDIQUI: Try starting a thread explaining a little about yourself, what you are qualified in and what your job entails. This might help people to help you. Or update your personal profile to include a bit of information. Also, a kind thankyou to those that help never goes amiss - and dont forget to rate answers as good answers of they help you.
Kind Regards
Kev Brown
Good Answers: 19
10/09/2008 12:54 PM
Yes I did also receive his e-mail and apologized to him and offered to help him out.
You are 100% right.
Register to Reply 8 comments
ducon (4); Kev_brown (2); Owen Jenkins (1); pipewelder (1)
