Previous in Forum: Optical Displacement Measurement Via Shadow Moire   Next in Forum: Model Engine: 1/4 Scale Rolls-Royce Griffon 65
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Marine Engineering - New Member Engineering Fields - Aerospace Engineering - Aeromarine Vehicle Engineer
Vena Contracta
10/07/2008 6:29 PM
Does the Vena Contracta of a sharp edge orifice that discharges air directly to the atmosphere varies from that when it discharges into pipe that is open to the atmosphere?
Pathfinder Tags: flowmeter
Re: Vena Contracta
10/08/2008 4:29 AM
Er, run that question again, please.
Good Answers: 15
Re: Vena Contracta
10/08/2008 5:56 AM
I see on wikipedia that there is no mention of this phenomenon differing. They even give a typical number for use in calculations.
This google search shows 304,000 results.......
If you don't have time to do it right the first time, when are you going to have time to do it over?
Re: Vena Contracta
10/08/2008 12:26 PM
Figure 3.25 from http://www.aeromech.usyd.edu.au/aero/cvanalysis/node3.shtml#node43 - sorry, link no longer available
I am curious if an orifice flowmeter that discharges directly to atmosphere would have the same vena contracta diameter as one discharging into a short length pipe that is opened to atmosphere. All the calculations I have found are for orifices that discharge directly into a pipe that is the same diameter as the inlet pipe.
Register to Reply 3 comments
charlie_r (1); Gannet (1); PWSlack (1)
You might be interested in: Steam Traps, Air Valves, Compressed Air Dryers
